no reaction in Halshow !
11 years 2 months ago #61813 by nooob
Hi guys,
i have an problem i want to read out the status of halui.jog.2.minus and halui.jog.2.plus but in halshow is no switching from False to True when i press the softkey in axis why?
the reason why im asking is that i want to disable the jog + softkey for the z axis in the axisui when an external sensor is triggerd.
sry for my bad English
greetings from Germany
11 years 2 months ago #61825 by cmorley
Replied by cmorley on topic no reaction in Halshow !
halui and axis are two separate programs used to communicate with the linuxcnc motion controller.
They do not communicate with each other.
And motion does not broadcast current jogging requests.
You would need to modify AXIS for this type of control
Chris M
11 years 2 months ago #61857 by nooob
Replied by nooob on topic no reaction in Halshow !
Thanks,
i never programmed with python before. so i have no experience.
Is there a way to work with an Output From Halui like "Z is moving Positive" ?
11 years 3 weeks ago #63621 by Niko
Replied by Niko on topic no reaction in Halshow !
you can probably do it with DDT by watching the sign of the output . If you link it to Z position .
Check comp and DDT
P.S. Check the probe option . G38
Cheers
Nikolai
11 years 3 weeks ago - 11 years 3 weeks ago #63631 by Rick G
Replied by Rick G on topic no reaction in Halshow !
Are you using hal show or hal watch?
To see a change to sure to select the "watch" tab.
Hal show will not show a change of state, only the state when selected hal watch will.
Rick G
Last edit: 11 years 3 weeks ago by Rick G.
Time to create page: 0.264 seconds
