Pokeys_homecomp EncoderSearch / Encoder Arm Topic: Pos_Fb Following errors
02 Dec 2018 22:05 #121730
Replied by andypugh on topic Pokeys
Whatever else is wrong, you definitely need to loadusr the component before you try to set any of its pins. The pins won't exist until it is loaded.
-W should mean that the loadusr command waits for the component to be ready before continuing.
When you say "Didn't work" what error message do you see?
- Erikcnc
04 Dec 2018 09:52 - 04 Dec 2018 10:02 #121802
by Erikcnc
Replied by Erikcnc on topic Pokeys
This is what i got now.
in my_mill.hal file
in postgui_call_list.hal file
If i use terminal with:
Pokeys response to the switches i installed before. Check, pokeys works.
I close terminal.
I start Linuxcnc (Gmoccapy)
Emergency butten ---> Machine Enable.
Go to settings ---> button Halshow
I go to watch en selecting the pins from the pokeys.
No response from my pre installed buttons.
Eny one got an example how it should look like?
in my_mill.hal file
loadusr -W pokeys
net all-home pokeys.0.in-2 => halui.home-allin postgui_call_list.hal file
setp pokeys.0.devSerial 38163If i use terminal with:
halrun
halcmd: loadusr -W pokeys
halcmd: setp pokeys.0.devSerial 38163
halshowPokeys response to the switches i installed before. Check, pokeys works.
I close terminal.
Last edit: 04 Dec 2018 10:02 by Erikcnc.
04 Dec 2018 10:26 #121803
Why do you have a different order of execution in your "real" HAL than when testing?
Where did you get the pokeys HAL driver from?
- Erikcnc
04 Dec 2018 14:35 - 04 Dec 2018 15:11 #121807
by Erikcnc
I followed the installation from this topic (page 1)
After i continued reading this topic, on page 5 i read this:
My apologizes for my lack of language. I try my best to explain my issue. I really hope to get it to work.
Erik
Ok,I think I've got it!
Yesterday I was testing the system. thinking first in the update I moved my debian wheezy to debian jessi and afterwards tried to update linuxcnc.Everything seemed right until I tried to open my-mill then a linuxcnc error appeared. I thought the issue was because I had created the file in the older version so I created a new one but had no success. Desperate and a little upset I made an afresh installation of debian wheezy, I updated cnclinux and was able to open up the file.
I went back to do all the steps Fixer stated from page 1 and connected the Pokeys in windows to know the serial number. In the file my-mill.hall I wrote loadusr pokeys, ran the linuxcnc and was now able to see the pins. I shut down linuxcnc and now in my-mill.hall I wrote pokeys.0.devSerial 66258 save file and try to open linuxcnc send me an error:Debug file information: . ./my-mill.hal:7: parameter or pin 'pokeys.0.devSerial' not found
I change the code loadusr pokeys and pokeys.0.devSerial to custom.hal and show me an error, if I put the loadusr pokeys in my-mill.hal and pokeys.0.devSerial66258 in custom.hal linuxcnc run fine, and pokeys.0.err are false and pokeys.0.alive start blinking. Is this procedure correct?
I tried to use estop with pokeys to test but i did not get it work, in custom.hal I wrote net estop-ext <= pokeys.0.in-52 it dont send me errors and in HAL configuration the pin 52 show :
Owner Type Dir Value Name
7 bit OUT FALSE pokeys.0.in-52 ==>estop-ext
Thank you so much for your help, have a nice day.
Erik
Last edit: 04 Dec 2018 15:11 by Erikcnc.
04 Dec 2018 14:49 #121808
Is it possible that you need to recompile linked to a different RTAI system?
From the starting post:
There are quite a number of explicit references to a specific RTAI path in there.
gcc -Wall -Os -g -I. -I/usr/include/libusb-1.0 -I/usr/include -L/usr/lib/ -L/usr/lib/arm-linux-gnueabihf/ -lPoKeys -lusb-1.0 -I/usr/realtime-3.4-9-rtai-686-pae/include -I. -I/usr/realtime-3.4-9-rtai-686-pae/include -I/usr/include/i386-linux-gnu -U_FORTIFY_SOURCE -D_FORTIFY_SOURCE=0 -fno-math-errno -funsafe-math-optimizations -fno-rounding-math -fno-signaling-nans -fcx-limited-range -mhard-float -DRTAI=3 -fno-fast-math -mieee-fp -fno-unsafe-math-optimizations -DRTAPI -D_GNU_SOURCE -Drealtime -D__MODULE__ -I/usr/include/linuxcnc -Wframe-larger-than=2560 -URTAPI -U__MODULE__ -DULAPI -Os -o pokeys ./pokeys.c -Wl,-rpath,/lib -L/lib -llinuxcnchalThere are quite a number of explicit references to a specific RTAI path in there.
04 Dec 2018 14:53 #121809
No, forget that, it has already been shown to work on your current system.
Try addingafter the "loadusr pokeys" line in the HAL.
Also, start linuxcnc from the command-line (command "linuxcnc") and paste all the output here.
Try adding
show pinAlso, start linuxcnc from the command-line (command "linuxcnc") and paste all the output here.
- Erikcnc
04 Dec 2018 15:14 #121810
by Erikcnc
Oke thanks!
I will try this evening.
Try addingafter the "loadusr pokeys" line in the HAL.show pin
Oke thanks!
- Erikcnc
06 Dec 2018 08:30 - 06 Dec 2018 08:33 #121931
by Erikcnc
Works like a charm!
Thank you so much for the support!
A overview how it works for me.
in my_mill.hal file
Home-all works also without going to the home tab.
i got also three 10K potetiometer to use as feed, maxvelocity and spindle override.
How could i get this to work though?
in my_mill.hal file
loadusr -W pokeys
show pin
# --- HOME-ALL ---
net all-home pokeys.0.in-2 <= halui.home-all
# ---CYCLE START ---
net program.run pokeys.0.in-0 <= halui.program.run
# ---CYCLE STOP ---
net program.stom pokeys.0.in-3 <= halui.program.stop
setp pokeys.0.devSerial 38163i got also three 10K potetiometer to use as feed, maxvelocity and spindle override.
Last edit: 06 Dec 2018 08:33 by Erikcnc.
06 Dec 2018 10:35 #121940
Well, that's weird.
"show pin" was only meant as a way to get some output to check if the pin existed. It wasn't meant to fix the problem.
Does the problem un-fix if you take the "show pin" back out again?
I don't see any reason for "setp pokets.0.devSerial" to need to be in the postgui call list.
It looks like some sort of race condition, which is odd as the -W should wait for completion.
Do you have the potentiometer values appearing and changing in HAL?
- Erikcnc
07 Dec 2018 11:06 #122000
by Erikcnc
I could try to remove 'show pin' and check if its realy that issue.
Another thing, those arrows are they have a function? Does it make a difirents how you insert them? ( <= or => )
About those potentiometers, i set them as analog input with the pokeys software.
I have to check how i can see values insted of I/0 dots.
Well, that's weird.
Time to create page: 0.271 seconds
