Air pressure stop motion question
29 Jan 2016 21:20 #69259 by Jake
Air pressure stop motion question was created by Jake
I got this line of code to work in the my io.hal
I thought since I had designated it air-alarm when it came into alarm it would say air-alarm
It does do the trick of "motion inhibit" stopping the machine from running, but I was hoping to make it say air-alarm so I know for sure what triggered the motion inhibit.
Or is there more that I have to do for the desired description in the alarm window?
# Air Pressure Switch DI 28
newsig air-alarm bit
net air-alarm motion.enable ppmc.0.din.28.in-not
Thanks!
30 Jan 2016 00:37 #69261 by cmorley
Replied by cmorley on topic Air pressure stop motion question
depending on the GUI you use thre are different methods.
If using AXIS the probably using the message component will do what you want.
www.linuxcnc.org/docs/2.7/html/man/man9/message.9.html
Gmoccapy has it's own message dialog system available, but message component will work with it also.
you would connect it to the same air-alarm signal.
Chris M
The following user(s) said Thank You: Jake
30 Jan 2016 08:35 #69271 by Jake
Replied by Jake on topic Air pressure stop motion question
Thanks I'll give that a shot this weekend
01 Feb 2016 11:33 - 01 Feb 2016 11:34 #69375 by Jake
I am not totally following the page example, on my first try it did not do anything. Still loaded but when you killed the air the message did not appear.
I tried this now, does this look like this is correct? Ill try it on my machine tonight. I have it commented out in Git, ill un comment it in the file.
#loadrt message names=air-alarm messages="LOW AIR PRESSURE"
#addf air-alarm iocontrol
#setp air-alarm.edge 0 #this pin should be active low
#net air-alarm motion.enable ppmc.0.din.28.trigger
Thanks!
Last edit: 01 Feb 2016 11:34 by Jake. Reason: dumb
03 Feb 2016 17:21 - 03 Feb 2016 17:29 #69534 by Jake
well it does not like the additional code for the message. It wont load with it. do any of yall see where I went wrong on it?
I am using axis btw...
#addf motion.enable iocontrol
#setp motion.enable.edge 0 #this pin should be active low
Or is this closer to what it needs to be?
Thanks!
Last edit: 03 Feb 2016 17:29 by Jake.
03 Feb 2016 22:34 - 03 Feb 2016 22:37 #69564 by Todd Zuercher
Replied by Todd Zuercher on topic Air pressure stop motion question
The newsig command is depreciated and is unnecessary.
All you need is the net command.
As you saw this only does the stopping part, to create your pop up message, you need quite a bit more.
loadrt message names=airpressure="Low Air Pressure"
addf airpressure servo-thread
net air-alarm airpressure.trigger
I'm not 100% sure about the above code, (never set this up before my self.
Last edit: 03 Feb 2016 22:37 by Todd Zuercher.
04 Feb 2016 21:03 #69630 by Jake
Thanks Todd,
I'll give that a shot in the morning!
Time to create page: 1.111 seconds
