sending current position over UDP ?
- flipflop
27 Feb 2016 09:20 #70708
by flipflop
sending current position over UDP ? was created by flipflop
Hey!
Is here a way to send updates of current position over UDP? What is the best method? Don't want to reinvent wheel. Googling didn't help for some reason.
- Thank you received: 5336
27 Feb 2016 13:19 #70719
Replied by PCW on topic sending current position over UDP ?
The short answers are " yes" , and "it depends"
If you explained what you are trying to do, its more likely someone could provide a better answer
- flipflop
27 Feb 2016 13:27 #70720
by flipflop
Replied by flipflop on topic sending current position over UDP ?
i'm just playing with android. Wanna build a simple app that would just display the current position of the mill and its rpm.
27 Feb 2016 14:15 #70728
Since you just need to read hal pins there's probably something clever that can be done
either with halcmd or a python network script with the hal interface (a userspace hal component)
- flipflop
27 Feb 2016 14:26 - 27 Feb 2016 14:27 #70729
by flipflop
Do I understand it correctly that emc2 exposes all its hal pins to the operating system? Does it basically have these values in some files that can be read from some external script, so I will just need to build a script that either would read those files in a loop and send values over udp, or (which is better) look for changes in these files (or receive notifications of such changes from emc2) and then transfer these new values over udp? How do I access coordinates from python?
Anyways, may be you know of any handy tutorial?
Last edit: 27 Feb 2016 14:27 by flipflop.
27 Feb 2016 16:21 #70732
Do you want to just do that, or write something to do that?
If a ready-made solution is acceptable: wiki.linuxcnc.org/cgi-bin/wiki.pl?Rockhopper_Web_Server
When I want to sit in the warm house waiting for the machine on the cold garage to finish, I use ssh.
Replied by andypugh on topic sending current position over UDP ?
ssh -Y andypugh@mill.local
halcmd -kf
loadusr halmeter -s pin motion.program-linePlease Log in or Create an account to join the conversation.
- mariusl
28 Feb 2016 00:07 #70743
by mariusl
Regards
Marius
www.bluearccnc.com
Replied by mariusl on topic sending current position over UDP ?
You definitely do it in a Python script that is loaded at run time by HAL. I have done that before with the arduino and except for a short delay every now and then, it give good throughput.
I will see if I can find that work again and post it here for you to look at.
Regards
Marius
www.bluearccnc.com
- mariusl
28 Feb 2016 00:14 #70744
by mariusl
Regards
Marius
www.bluearccnc.com
Regards
Marius
www.bluearccnc.com
The following user(s) said Thank You: flipflop
- flipflop
28 Feb 2016 07:26 #70747
by flipflop
It looks like the first file there is a hal setting file, the third file is a python script file, and the second one looks like your code for arduino? If you provided a bit more comments, it woull have been much easier. So far what I see is manipulation with pins and their states, but if I don't want to make my script count pin state changes, is there a way to read coordinates directly?
- mariusl
28 Feb 2016 08:50 - 28 Feb 2016 08:54 #70750
by mariusl
Regards
Marius
www.bluearccnc.com
The code was not meant to be for public use but rather just a test to see what can be done on UDP.
The bits you want to look at is the network stuff, not really the arduino or i/o stuff. You can connect to HAL signals in a similar fashion as what I did with the I/O.
You will have to use a bit of imagination I am afraid.
P.S. Read the thread as it gives a lot of information. Also the comments in the Python file
Regards
Marius
www.bluearccnc.com
Last edit: 28 Feb 2016 08:54 by mariusl.
Time to create page: 1.095 seconds
