active jog change
- Wolfmansbrother
28 Feb 2016 22:55 #70794
by Wolfmansbrother
active jog change was created by Wolfmansbrother
Sorry if this topic has been covered or is trivial.
I just set up my Logitec Wingman Attack to jog the axis on my mill.
Currently the jog is just a static setp number
I understand how to map inputs to pins to control them.
I don't know how to make an t/f input add or subtract from a parameter, how can i do this?
29 Feb 2016 05:36 #70803
You would commonly use a mux2 HAL component to choose one of two values then either use that value directly or add it to some other value.
If mux2 is not suitable (need more inputs, need a different data type) then there is a mux4, mux8 or mux_generic as an alternative
Replied by andypugh on topic active jog change
The following user(s) said Thank You: Wolfmansbrother
Time to create page: 1.033 seconds
