Simple question (for someone else...)
11 Mar 2016 12:58 #71443 by fishtruk
Simple question (for someone else...) was created by fishtruk
Hello,
I want to have one of the inputs on our probotix pbx-rf card (parallel breakout board) to trigger stepping a program thru line by line...just as if you pressed the "T" key. Has anybody HAL code for this?
Thanks,'
Nelson
11 Mar 2016 21:41 #71479 by cmorley
Replied by cmorley on topic Simple question (for someone else...)
you could connect a parallel port pin to halui's pin: halui.program.step
something like..
net single-step-button halui.program.step parport.0.pin-10-in
Then if you paused the program toggling the port pin should step the program.
I haven't tried it.
Chris M
Time to create page: 0.678 seconds
