how to change motor spin directions?
10 years 7 months ago #72235 by famus
Yes. that's an idea! However, I should know why the float spinbox wouldn't take a negative number. I tried:
setp stepgen.0.velocity-cmd -2
and it worked to reverse direction. I should read up GladeVCP how to set range.
Thank you!
10 years 7 months ago - 10 years 7 months ago #72243 by Todd Zuercher
To set up a spin-button you have to have an Adjustment widget associated with the spin-button and that is where you set the range of values that can be output by the spin-button.
So if you are using an existing example Gladevcp you will need to open it in the Glade editor, open the adjustment widget associated with your spin-button, and change the minimum value there to a negative number (instead of the default of 0).
Last edit: 10 years 7 months ago by Todd Zuercher.
Time to create page: 0.055 seconds
