round () function not work ?
- gaston48
- Thank you received: 5
24 Mar 2016 17:51 #72104
by gaston48
round () function not work ? was created by gaston48
Hello,
The mathematical round () function is present in "rtapi_math.h" but
I can not get it to work ?
ceil () and floor () work well.
Someone could try
thank you vey much !
Someone could try
- jepler
- User is blocked
- Thank you received: 33
24 Mar 2016 20:14 #72110
by jepler
Replied by jepler on topic round () function not work ?
We have a test of the availability of math functions. In our 2.7 branch, it includes the following note:So, as far as versions built by linuxcnc.org are concerned, if you are using Ubuntu Lucid with RTAI 3.8.1, round() is not available. This may also apply to older releases from linuxcnc.org. Otherwise, I expect that it is available.
// rtapi_math.h includes a declaration for round(), but the LinuxCNC RTAI
// packages up through RTAI 3.8.1 (which we packaged for Ubuntu Lucid)
// did not include round(), so we skip that test here. RTAI 3.9 and
// 5.0-test1 (packaged for Debian Wheezy and Jessie, and Ubuntu Precise)
// do include round().Please Log in or Create an account to join the conversation.
- gaston48
24 Mar 2016 21:09 - 24 Mar 2016 22:08 #72112
by gaston48
Replied by gaston48 on topic round () function not work ?
Thank you for your search.
I am currently in version 2.7.4 with Debian Wheezy
then I think round () is still not available
It is accepted by the compiler, but it does
not the calculation rounding.
Why it's just round () is not available and many
other complex functions are available?
if this is not possible with round(), I'll do it with " floor (in + 0.5) "
Last edit: 24 Mar 2016 22:08 by gaston48.
Time to create page: 0.083 seconds
