How to set function update period
07 Apr 2016 07:40 #72906 by Eric282000
How to set function update period was created by Eric282000
This is from the hal componet documentation.
function NAME. The function includes a parameter period which is the integer number of nanoseconds between calls to the function.
How would I use the period parameter to make the function only update once per second?
I would like to run the component under the servo - thread but have one of the functions called one per second.
07 Apr 2016 07:43 #72908 by andypugh
Replied by andypugh on topic How to set function update period
accum += period
if accum >= 1000000000 {
accum = 0
do_stuff
The following user(s) said Thank You: Eric282000
Time to create page: 0.924 seconds
