Problem with homing ATC step motor
- CNCDoc
04 Oct 2019 00:37 #147096
by CNCDoc
Replied by CNCDoc on topic Carousel Component add jog buttons
Will do it tonight.
But it looked the same on both the new and the old .comp.
- CNCDoc
05 Oct 2019 10:41 #147203
by CNCDoc
XXX@XXX:~/linuxcnc$ sudo halcompile --install carousel.comp
[sudo] password for XXX
Compiling realtime carousel.c
Linking carousel.so
cp carousel.so /usr/lib/linuxcnc/modules/
XXX@XXX:~/linuxcnc$
Linking carousel.so
XXX@XXX:~/linuxcnc$
05 Oct 2019 13:45 #147214
Replied by andypugh on topic Carousel Component add jog buttons
Well, that looks OK.
You are running installed rather than run-in place LinuxCNC?
Is there any other carousel.so on your system?
- CNCDoc
06 Oct 2019 00:52 #147235
by CNCDoc
Installed following instruction 7.1 in the following link
linuxcnc.org/docs/html/getting-started/getting-linuxcnc.html
I'll check.
I'll check.
- CNCDoc
06 Oct 2019 08:47 #147247
by CNCDoc
The only carousel.so I find is in:
/ Usr / lib / linuxcnc / modules /
The carousel.so I'm using now comes from post 58732. If it does matter
06 Oct 2019 11:32 #147260
If you revert to the previous carousel component code and halcompile that, does it then work?
Is it _definitely_ a problem with carousel? If you comment out all references to carousel does the system then load normally?
- CNCDoc
06 Oct 2019 11:45 - 06 Oct 2019 12:41 #147265
by CNCDoc
If you revert to the previous carousel component code and halcompile that, does it then work? Yes
If you comment out all references to carousel does the system then load normally? Yes
Last edit: 06 Oct 2019 12:41 by CNCDoc.
08 Oct 2019 22:43 #147527
I am afraid that I am baffled then, as lots of people (including myself) have successfully used the new version so control lool changers.
There is less scope for weirdness than normal too, as Halcompile does most of the work, and that is well tested and compiles all the other components.
I suppose it is just possible that you are specifying an untested set of command-line parameters. What is your "loadrt" line?
- CNCDoc
09 Oct 2019 11:04 #147571
by CNCDoc
loadrt carousel pockets=15 dir=1 encoding=bcd num_sense=5
loadrt conv_float_s32
addf carousel.0 servo-thread
addf conv-float-s32.0 servo-thread # G-code analogue outputs are float-type
18 Oct 2019 07:41 #148187
I am back from my travels, I will try to look at this again soon.
I do wonder if 15 pockets (not a power of 2) is the problem.
(And 5 sense pins is one too many to encode 15 pockets)
Time to create page: 1.066 seconds
