physical start button + pause switch
9 years 10 months ago #83817 by SenorAguas
Thanks, it worked the same as far as I can tell. Still had the same error message during certain moves, which seemed to be the interpolated moves.
9 years 10 months ago #83824 by Todd Zuercher
Sorry, I really don't know, right now I can't seem to reproduce the error message. What version Linuxcnc and what OS are you using?
9 years 10 months ago #83836 by an92626
SenorAguas
I happened upon your thread because I was having the same problem getting the "can't do that" error message. Operationally it did not cause a problem, it was just annoying getting the error message.
I seem to have resolved my problem by pausing and then stopping.
You may wish to try editing your hal file in the pause section.
Just before you have the statement: net pause-sig halui.program.stop <= and2.0.out,
you may wish to trying adding the statement:net pause-sig halui.program.pause <= and2.0.out
This is what I did and from the limiting testing I did it seemed to stop the "can't do that" error message. I can not give you an explanation why it worked, but there are many things in linuxcnc that I can not explain. It would be a quick test and if it gets rid of the annoying error message then you can move on. Pause the program and then stopping it should not make any difference operationally that I can tell.
9 years 10 months ago #83873 by cncnoob1979
Warning: Spoiler!
Here is my hal file that is using two physical buttons for what you are asking for. I hope it helps, my hal is a work in progress. So dont mind the mess please! :) Has worked fine for me in master and previous versions.
Time to create page: 0.418 seconds
