Relation between HAL pins and EtherCAT Slave Information(ESI) .xml file?
9 years 11 months ago - 9 years 11 months ago #83509 by jerryCNC
I am trying to write EtherCAT HAL driver for Beckhoff servo drive AX5000:
* I studied the template of Sittner's driver for DELTA Electronics ASDA series:
--- github.com/sittner/linuxcnc-ethercat/blo...er/src/lcec_deasda.h
* And I studied the EtherCAT Slave Informaion(ESI) file for DELTA Electronics ASDA series:
--- see attached .xml file.
I am wondering how Sittner figured out those HAL pins, which are not found in the ESI(.xml) file?
Thanks!
File Name: ASDA2-Erev3.35.xml
File Size:177.73 KB
File Name: lcec_deasda.h
File Size:4.11 KB
File Name: lcec_deasda.c
File Size:26.02 KB
Last edit: 9 years 11 months ago by jerryCNC.
9 years 9 months ago #85481 by chimeno
Hello, I just pulled out an AX5203 driver and I would like to connect to linuxcnc, have you been able to make them work?
Thank you
9 years 9 months ago #85575 by jerryCNC
Hi, I figured out the HAL logic for linuxcnc.
However, the main problem for AX5000 is not from linuxcnc, but from IgH-EtherCAT-master:
* I am stuck at using IgH-EtherCAT-master to control AX5000.
* You can forget about linuxcnc before solving this problem.
By the way, which hardware are you using as EtherCAT master?
The following user(s) said Thank You: chimeno
9 years 9 months ago #85590 by chimeno
Hi, thanks for the answer, to your question you are referring to what hardware I am using?
9 years 9 months ago #85595 by jerryCNC
Yes, what real-time OS is running in what hardware?
As you study more, you will find that distributed-clock is a big issue for controlling AX5000 with IgH EtherCAT master.
9 years 9 months ago #85624 by chimeno
Hi I am currently using linuxcnc 2.7.8 with mesanet 5I20.
I have two servosystems in AX5203 and AX5206, if we can connect them to linuxcnc
Thank you
Time to create page: 0.063 seconds
