[solved]halui telop mode & joint mode settings
- bkt
- Thank you received: 113
10 Jan 2017 14:41 - 19 Jan 2017 15:57 #85571
by bkt
[solved]halui telop mode & joint mode settings was created by bkt
so during my test for solve the comp generator issue verify a strange problem seeng with hal configurator (axis gui) ....
machine is homed... is on
but not see error .... only the axis not perform teleop mode .....
What are the condition that make pèossible the switch from joint mode to teleop??
Giorgio
halui.mode.manul -> true
halui.mode.joint -> false
halui.mode.teleop -> true
halui.mode.is-manual -> true
halui.mode.is-joint -> true /*** but expect false******/
halui.mode.is-teleop -> false /**** but expect true****/
Giorgio
Last edit: 19 Jan 2017 15:57 by bkt.
- dgarrett
- Thank you received: 325
10 Jan 2017 15:00 #85572
by dgarrett
Replied by dgarrett on topic halui telop mode & joint mode settings
Assuming you are using git master branch:
halui.mode.teleop and halui.mode.joint are edge-triggered
inputs so typically pulsed.
you can try simulating with
sim_pin halui.mode.joint/mode=pulse halui.mode.teleop/mode=pulse
The following user(s) said Thank You: bkt
- bkt
11 Jan 2017 09:44 #85607
by bkt
Replied by bkt on topic halui telop mode & joint mode settings
perfect ... the condition for halui.mode.mdi is halui.mode.joint or teleop??
Giorgio
Giorgio
- bkt
14 Jan 2017 14:21 #85749
by bkt
an other stupid error ..... halui.mode.mdi needs halui.mode.joint ....
sorry
Giorgio
sorry
Giorgio
Time to create page: 0.094 seconds
