motion.digital -- reset
- bevins
- Thank you received: 338
04 May 2018 19:53 - 04 May 2018 20:08 #110226
by bevins
Replied by bevins on topic motion.digital -- reset
I didn't read the post completely so my suggestion was not valid here...
But Interesting topic.
Last edit: 04 May 2018 20:08 by bevins.
- bkt
- Thank you received: 114
05 May 2018 00:00 #110232
by bkt
Replied by bkt on topic motion.digital -- reset
When i find the time to develop these type of comp (really not so difficult ... the difficulty is having the time to read all the .cc files that tell you the exact way to do it) .... for sure I post it here.
giorgio
giorgio
- fsabbatini
- Thank you received: 83
09 Aug 2021 12:51 #217324
by fsabbatini
Replied by fsabbatini on topic motion.digital -- reset
Sorry for bringing this post up, but i wanted a fanuc- or siemens-like behaviour: upon reset (ABORT), just reset all outputs.
For this just add
for (n = 0; n < emcmotConfig->numDIO; n++) {
*(emcmot_hal_data->synch_do[n]) = 0;
*(emcmot_hal_data->synch_di[n]) = 0;
in command.c and compile linuxcnc
Regards
Franco
For this just add
Regards
Franco
The following user(s) said Thank You: tommylight, bkt
10 Aug 2021 19:26 #217449
Replied by andypugh on topic motion.digital -- reset
Resetting the inputs is probably a bad idea.
- fsabbatini
10 Aug 2021 19:47 #217453
by fsabbatini
Why do you think so?
I have it working for a while perfectly,
so what i do is the following, i use the inputs and outputs to do M functions synchronized with the interpreter and the plc.
Fanuc and Siemens just set for one plc cycle the input and then reset it so you latch the current m function in the plc.
the thing is that if you use this inputs in the plc and then press reset button it will keep the last state without being able to reset them until you set or reset them in the cnc, i dont think this behavior is of any good...
Regards
Regards
10 Aug 2021 20:17 #217456
Because the inputs _should_ take the value of the driving HAL pin. The reading part of the system has no business changing the signal value.Why do you think so?
The following user(s) said Thank You: bkt
- fsabbatini
10 Aug 2021 20:23 #217457
by fsabbatini
thats true, im sorry, the inputs are not reset, just copy the part from init here
i reset just the outputs
thanks Andy for making me noticing i wrote it bad here
