run/pause/restore button
- caio
26 Apr 2017 14:29 - 27 Apr 2017 12:41 #92165
by caio
run/pause/restore button was created by caio
hi everyboby,
i would like to add an on/off button (on the same button) on my joypad.
i tried the example in this page (flood button)
wiki.linuxcnc.org/cgi-bin/wiki.pl?Using_...ove_Your_CNC_Machine
but when i press the button it switch on-off continuosly until button is released.
if i press it very very shortly, it work, but is a little dangerous for the machine.
i believe i need a flipflop, but i can't find the way to use it.
do you have some suggestion?
thanks
thanks
Last edit: 27 Apr 2017 12:41 by caio.
- Thank you received: 1482
26 Apr 2017 15:05 #92166
Replied by Todd Zuercher on topic double function button
I think you might want to use the
Toggle2NIST
and if you still have a problem with it going on and off, run the input through an
edge
detector.
- caio
27 Apr 2017 06:36 #92194
by caio
Replied by caio on topic double function button
i think i will need both.
thanks
thanks
- caio
27 Apr 2017 12:49 #92224
by caio
i like to share my code for run-pause-resume button on joypad:
hoping it can help someone.
##### BUTTON START-PAUSE-RESUME
loadrt and2 count=3
loadrt not count=2
loadrt edge count=1
setp edge.0.in-edge FALSE
setp edge.0.out-width-ns 100000000
net runPause0 input.0.btn-base4 => edge.0.in
net runPause1 edge.0.out => and2.0.in0
net runPause1 edge.0.out => and2.2.in0
net runPause1 edge.0.out => and2.3.in1
net runPause2 halui.program.is-running => not.0.in
net runPause2 halui.program.is-running => and2.2.in1
net runPause3 not.0.out => and2.0.in1
net runPause4 and2.0.out => and2.1.in1
net runPause5 and2.1.out => halui.mode.auto
net runPause5 and2.1.out => halui.program.run
net runPause6 and2.2.out => halui.program.pause
net runPause7 halui.program.is-paused => not.1.in
net runPause7 halui.program.is-paused => and2.3.in0
net runPause8 and2.3.out => halui.program.resume
net runPause9 not.1.out => and2.1.in0
addf and2.0 servo-thread
addf and2.1 servo-thread
addf and2.2 servo-thread
addf and2.3 servo-thread
addf not.0 servo-thread
addf not.1 servo-thread
addf edge.0 servo-thread
#####hoping it can help someone.
Time to create page: 0.205 seconds
