pyvcp and gladevcp using same signal halui.axis.x.minus
  • nicokid
  • nicokid's Avatar Topic Author
  • Senior Member
  • Senior Member
25 Jul 2017 04:16 #96374 by nicokid
I would like to live together pyvcp and gladevcp (I do not know if it's a good idea).
I have a jog button that does the same thing in both interfaces: x-minus.
So in my postgui HAL file I have inserted these lines:
net gvcp-jogxminus halui.axis.x.minus <= gladevcp.jog_x_minus
net my-jogxminus halui.axis.x.minus <= pyvcp.x-minus
But rightly I get this error:
Pin 'halui.axis.x.minus' was already linked to signal 'gvcp-jogxminus'
I have tried different combinations without success. Is there a way to share the "halui.axis.x.minus" signal?
Any help will be appreciated.
Nicola.
25 Jul 2017 08:25 #96386 by cmorley
feed the buttons in a or2 component then to halui
Chris M
The following user(s) said Thank You: nicokid
25 Jul 2017 09:19 #96392 by Todd Zuercher
You use the or2 like this:
#put this line with the rest of your loadrt lines.
loadrt or2 count=1
#put this line with the rest of your addf lines, the order of the addf lines matters.
addf or2.0  servo-thread
net gvcp-jogxminus <= gladevcp.jog_x_minus => or2.0.in0
net my-jogxminus <= pyvcp.x-minus => or2.0.in1
net jogxminus <= or2.0.out => halui.axis.x.minus
  • nicokid
  • Senior Member
  • Senior Member
25 Jul 2017 12:08 #96401 by nicokid
I had tried or2 but without success. I always have some understanding problem with the HAL pin :blink:
Now your code works perfectly :)
Thank you guys.
Nicola.
Time to create page: 0.260 seconds
