spindle tristate_index
  • billykid
  • billykid's Avatar Topic Author
  • Platinum Member
  • Platinum Member
29 Sep 2017 13:51 #99637 by billykid
spindle tristate_index was created by billykid
Hello
I managed to run the spindle orientation without index though.
Now that I work, I would like to use the spindle index enable.
I put tristate_bit and it works, in g76 is enabled and with M19 disabled
I'm not very clear how to link index-enable to orient mode, if anyone can help me ... just start that damn index!
Mauro
newsig tristate.index bit
sets tristate.index true
net tristate.index => tristate-bit.0.in
net spindle-index <= tristate-bit.0.out
net ori-index or2.2.out => tristate-bit.0.enable
net spindle-index <= motion.spindle-index-enable
net spindle-index <=> hm2_5i23.0.encoder.03.index-enable
  • billykid
  • Platinum Member
  • Platinum Member
03 Oct 2017 14:24 #99835 by billykid
Replied by billykid on topic spindle tristate_index
since it is too complicated to use the index, I compiled the component from master 2.8 and it works fine though after using the g76 first.
is there a way to do this automatically when linuxcnc starts?
thank you
Mauro
05 Oct 2017 02:25 #99951 by massimodamassa
Replied by massimodamassa on topic spindle tristate_index
You can maybe run a G76 close to zero machine so it does not cause any problems.
For example
G59
T1M6
M3S100
G76 P1 Z-10 I-2 J0.5 K3,065 H1 R2 Q30 E1 L1
G28X0Z0M5
G54
M30
05 Oct 2017 07:26 #99958 by andypugh
Replied by andypugh on topic spindle tristate_index
It might suffice to have a "sets spindle-index 1" in your HAL file. Then the encoder will zero on the first pass through index, and should then be correct for the remainder of the session.
Just make sure you don't try to orient until the spindle has one one full rev.
I have a branch waiting to be merged (after 2.8) that will support multiple spindles and also allow spindles to be part of the home sequence.
The following user(s) said Thank You: billykid
  • billykid
  • Platinum Member
  • Platinum Member
05 Oct 2017 08:46 #99959 by billykid
thanks Andy works!
apparently it is not possible to set this signal with the orient mode.
I tried but I did not succeed ... but that's fine, then if in 2.8 it will be better.
Time to create page: 0.131 seconds
