setp encoder scale by mux2
14 Oct 2017 19:56 #100360 by andypugh
Replied by andypugh on topic setp encoder scale by mux2
I've seen but I do not understand if it can serve.
the problem that the spindle enabled turns very slowly instead of being stationary.
Sorry, I misunderstood. No, inverse dead band is no help here.
  • billykid
  • billykid's Avatar Topic Author
  • Platinum Member
  • Platinum Member
14 Oct 2017 20:05 #100361 by billykid
Replied by billykid on topic setp encoder scale by mux2
I can not explain well with the translator ...
the pid is running, not good because it is a 15 kw motor and has some inertia plus spindle and belt drive.
since research is done at 15 mv max otherwise it starts to oscillate, I thought those 5 mv could worsen the search.
Time to create page: 0.092 seconds
