- Thank you received: 216
robertspark wrote: thanks Andy, I can create the pins (all 112) no problem and change their status from true to false.
I am looking for is simple means to input keypresses into the MDI.
It probably makes sense to read a config file, which is a list of rows and columns, and create HAL pins or keystrokes accordingly.
Something like:Which would create HAL pins called "coolant" and "run" and send a 44 key event (KEY_Z) for the third. And do nothing for the blanks or for rows/columns omitted.Code:r1c1 pin coolant r1c2 pin run r1c3 key 44 r1c4 r1c5 ...
Parsing in Python can be done with regexes, to parse the above format:Code:import re ... [row, column, type, val] = re.split("r(\d*)c(\d*) (.*?) (.*)", "r1c2 pin hello")[1:5]
I find this web site invaluable for experimenting with regexes: regexr.com
I think that python-evdev looks like the best way:
python-evdev.readthedocs.io/en/latest/
This seems a close match to the way that my sendkeys component does it in C.
The keycodes are here: wiki.linuxcnc.org/cgi-bin/wiki.pl?Scancodes
