- Thank you received: 106
bbsr_5a wrote: on ebay there are many controll panels for CNc machines and manufactuers lke HAAS VF serias use a USB compatible keyboard
that can be connected to a COMP
BeagleBrainz wrote: Can out get physical access to the row\col of the keyboard matrix ? if so a 7i73 could be the answer if you are going the MESA route of a custom USB solution, Arduino ProMicro or another mcu that has native USB.
Or as per your solution an MCU reading the serial and connecting via USB.
Any pics of the guts of the device ?
I do have pics, but it's basically a PIC, a serial interface etc. The keyboard is of course a row/col matrix, but the hardware is doing just fine. The serial interface works perfectly - the cable etc is a regular one, and I've got a couple of serial interfaces on the industrial PC's that I use.
The only real question is how I can get the ASCII from the serial interface and into LinuxCNC.
