axis.5.motor-pos-cmd = -nan
06 Nov 2017 09:47 #101404 by andypugh
Replied by andypugh on topic axis.5.motor-pos-cmd = -nan
As my next step I would comment-out everything related to the axis in HAL and see if the problem still occurs.
You can then run the HAL commands one-by-one in an interactive HAL session (halcmd -kf after LinuxCNC loads) to see if you can work out where the problem starts.
Are you using Trivkins?
06 Nov 2017 11:17 #101408 by Henk
Replied by Henk on topic axis.5.motor-pos-cmd = -nan
Hi Andy
Yes, I'm using trivkins.
Ill try that, thanks
Henk
06 Nov 2017 11:23 #101410 by andypugh
Bad kinematics code can give the effect seen, but Trivkins doesn't do any mathematics, so it can't be that.
I have once seen this when a HAL component was writing out of its memory space (array bounds problem). I doubt that is the case here, but changing the order of the "loadrt" lines in the HAL would give some indication if this was the case.
06 Nov 2017 12:59 #101420 by Henk
With everything removed from the HAL file relating to the C-axis, the gui loads and immediately axis.5.motor-position-cmd show -nan.
I have checked the .ini file and cannot see anything wrong.
maybe I should try to update, current version is 2.7.8 I think
Henk
06 Nov 2017 14:01 #101424 by andypugh
Updating will certainly fix some problems, and is a very simple process via the package manager.
But I doubt that it will help with this problem.
07 Nov 2017 12:33 #101489 by Henk
Hi
I managed to correct this error, but unfortunately I still don't know what caused it....
I copied the previous config and made the changes required and this issue didn't show up. Is it possible that something in the .ini file can cause this?
Anyway, I can now start testing and debugging gearhob.comp
07 Nov 2017 13:00 #101490 by andypugh
Possibly, if the INI file had a zero in it that something was getting divided by.
Time to create page: 1.381 seconds
