To be honest I am not sure how the Modbus registers map to the VFD parameters or how Seb worked out which register was which for the GT driver.
Comparing the output bits it seems that the feedback parameters might work but will be mis-named in HAL. For example output power in the GT is bit 7 (and register 0x3006 in the driver) whereas it is bit 6 on the SL, so using the GT driver with the SL the output power might appear on another HAL pin (I was going to say which one, but, actually, I am not sure that it is actually correct in the driver for the GT)
Have you actually tried it?
