During the work of the machine in the program was the command "M6", which the machine did not perform - the tool has not changed. The operator noticed this and pressed E-STOP and informed me. I did not turn off the machine and began to investigate the cause. I started the test program of tool change in a cycle - the tool did not change. However, the pin iocontrol.0.tool-change changed its state. Then I found that, despite the correct combination of input signals, flipflop does not change the state at the output. Using "halcmd unlinkp ....." I detached all the flipflop inputs and began to study its behavior by sending signals manually ...
After restarting LinuxCNC, this problem can not be repeated.
Continues these experiments there is no possibility - the machine is in production. I changed the HAL file by completely eliminating this trigger.
It is not possible to reproduce such a situation on the test bench.
