Spindle speed from PWM to analog (0-10)
8 years 11 months ago #101948 by Xpertmill
Hello everybody,
i bought this breakoutboad from ebay LINK . This board can generate a 0 - 10V analog voltage for my vfd by using pwm pulses. The problem i have now is, that at spindlespeed 30000 rpm (M3 S30000) the voltage is 0.05 V and at spindlespeed 1000 it is 9.6 V. But it should be about 10V at 30000 rpm and about 0.5V at 1000 rpm.
Can i invert the pwm output, that the pulses are minimal at 1000 rpm and maximum at 30000 rpm?
This is the part of my hal i used for the pwm generation:
loadrt pwmgen output_type=0 addf pwmgen.update servo-thread addf pwmgen.make-pulses base-thread net spindle-speed-cmd motion.spindle-speed-out => pwmgen.0.value net spindle-on motion.spindle-on => pwmgen.0.enable net spindle-pwm pwmgen.0.pwm => parport.0.pin-09-out # Set the spindle's top speed in RPM setp pwmgen.0.scale 30000
Thank you
Greetings
Michael
8 years 11 months ago #101950 by PCW
You probably want to invert the PWM output pin:
setp parport.0.pin-09-out-invert true
The following user(s) said Thank You: BSOD
8 years 11 months ago #101953 by Xpertmill
Thank you PCW!
i just checked it out. Works perfect!
Time to create page: 0.054 seconds
