Hi everyone,
I have retrofitted 5 or 6 machines now pretty successfully with LinuxCNC. Currently I am working on a plasma table that has an odd system. It controls the X and Y through stepper drivers (I have used the 5i25+7i76) and got everything including cutting working. However the Z-axis is controlled by a closed-loop THC. This system has three inputs in addition to all the other THC controls. Basically LinuxCNC does not need to control the Z-axis.
However the three inputs allow for rapid Z-up, Rapid Z-down, and slow Z-down. I would like to put some buttons in the gmoccapy to control these outputs through HAL. I am fairly sure this can be done, and fairly easy at that too. I just cannot find any examples to get me started. I was thinking to perhaps change the flood and mist coolant buttons in gmoccapy to do this and add another button. However these would need to be momentary buttons rather than the latching type which coolants currently are.
Cheers,
Omid
