Twopass
8 years 9 months ago - 8 years 9 months ago #104793 by Mike_Eitel
Twopass was created by Mike_Eitel
Hi
I want to use twopass quite intensiv
Is it possible that this funtionality is not working as expected in postgui files?
P.S. Stretch, newest master.
THX
Mike
Last edit: 8 years 9 months ago by Mike_Eitel.
8 years 9 months ago #104795 by dgarrett
Replied by dgarrett on topic Twopass
Twopass processing occurs before the loading of a gui. When using a [HAL]POSTGUI_HALFILE, it is convenient to place all the loadrt statements for components needed in a halfile that is loaded earlier. Example of a HAL section when using a POSTGUI_HALFILE : ---- [HAL] TWOPASS = on HALFILE = core_sim.hal HALFILE = sim_spindle_encoder.hal HALFILE = axis_manualtoolchange.hal HALFILE = simulated_home.hal HALFILE = load_for_postgui.hal <-- loadrt lines for components in postgui.hal POSTGUI_HALFILE = postgui.hal HALUI = halui ----
Ref: linuxcnc.org/docs/html/hal/twopass.html
It is possible that there are issues with very complex loadrt lines.
Post your ini and hal files.
8 years 9 months ago - 8 years 9 months ago #104797 by Mike_Eitel
Replied by Mike_Eitel on topic Twopass
After reading again i get the impression that it is not only convinient but demanded to collect the loadrt in an seperate file?
Yes, will do and collect ( pitty)
THX
8 years 9 months ago #104802 by Mike_Eitel
Nope
I changed, but it does not work neither,
also not to transfer addf was the reason
I have no glue anymore
THX Mike
File Name: MeBIG.tar
File Size:330 KB
8 years 9 months ago #104809 by dgarrett
I don't have hardware to test a 7i76e, Please:
1) run the following command in a terminal (test.hal attached)
and post (attach) the file tst.out
halrun tst.hal >|tst.out 2>&1
2) run linuxcnc from a terminal and post (attach) the file log.txt
linuxcnc MeBigCNC3.ini >|log.txt 2>&1
8 years 9 months ago #104812 by Mike_Eitel
Hi dgarrett
I'm no more near to my machine but my 7i76e/773 combo works good.
Only problem since the upgrade is the scrambled lcd.
For the twopass problem i changed all files and concentrated all loadrt in one preloaded file.
Since then it runs. I can proceed with my application building.
Do you still want me to run your test and send the result?
Thx Mike
Time to create page: 0.265 seconds
