Move axis for automatic tool change
23 Jan 2018 10:37 - 23 Jan 2018 10:39 #104898 by eriksalo
Move axis for automatic tool change was created by eriksalo
Hi;. I'm nearly done with an OKADA VM500 LinuxCNC retrofit. It's a big mid-80's VMC with a twenty position carousel style ATC.
I have all of the I/O hooked up and can do a tool change by hitting buttons on Axis/Glade. Now I want to automate to work with an M6 Tx command.
What is the preferred method of doing this? I need to move the Z-Axis during the course of the tool change. It's not clear how to do this in classic ladder.
Any suggestions?
Thanks; Erik
Last edit: 23 Jan 2018 10:39 by eriksalo.
23 Jan 2018 10:40 #104899 by skunkworks
Replied by skunkworks on topic Move axis for automatic tool change
take a look at the
linuxcnc/configs/sim/axis/vismach/VMC_toolchange/
example.
23 Jan 2018 15:26 #104921 by eriksalo
Replied by eriksalo on topic Move axis for automatic tool change
Thanks! I searched the docs and forum for hours and didn’t see this. Will go check it out.
18 Feb 2018 05:04 #106123 by andypugh
Replied by andypugh on topic Move axis for automatic tool change
Classic ladder has no way to move an axis.
So it is much easier to do a tool change like you are talking about with a G-code subroutine.
You can develop the subroutine first, then make it be called from M6 using G-code remapping.
However it probably makes sense to do the remapping first, as the supplied "stdglue" routines pass some useful parameters to the G-code.
I wrote the "carousel" HAL component specifically to interact with G-code routines, though it ought to work with Ladder too.
As mentioned earlier, the VMC_toolchange demo configs use both remapping and the carousel component. You can try them out (without moving any actual hardware) by choosing them from the config-picker in sim/axis/vismach/vmc_toolchange
Time to create page: 0.152 seconds
