Configuring LinuxCNC
HAL
EtherCAT configuration example
Thank you received: 0
04 Mar 2018 13:31 #106927
by HammersTR
I have little problem with ethercat configuration.
I have Panasonic AB5 drives. I followed "Little Tutorial for the use of Bosch Rexroth IndraDrives with LinuxCNC over EtherCAT" tutorial, but i couldn't figure out how to config ethercat slaves. I can list drives with "generic" mode, but this is not enough.
I did find xml file for the drive. How to configure linux cnc to work with 3 axes?
Thank you.
HAL
Time to create page: 0.097 seconds
