VFD mb2hal
6 years 5 months ago #168522 by Gnoem
Replied by Gnoem on topic VFD mb2hal
Thanks a lot! Have you maybe already succeeded to get a feedback from the VFD? Or realy found out whats needed to change in the hy_vfd file for the standart huanyang vfd for operating with the yl620? Honestly I dont understand how the commands are defined in the hy_vfd driver. As the functions are more or less the same in both models I thought its only changing of a few numbers, but as usual its more complicated...
6 years 5 months ago #168556 by aekhv
Replied by aekhv on topic VFD mb2hal
Gnoem wrote: ... to change in the hy_vfd file for the standart huanyang vfd for operating with the yl620?
Huanyang uses modified MODBUS protocol with non-standard function codes. It's wrong idea to modify it back to standard MODBUS functionality :) Try mb2hal with config file for YL620 above, zajc3w said it works.
Also probably you will be interested in other way to communicate with YL620: forum.linuxcnc.org/24-hal-components/391...communicaiton#168359
6 years 5 months ago #168565 by Gnoem
yes the code of zajc3w works. It was quite nice seeing the first time the spindle switching on and off by computer commands.
Still I want to go further. Let's see. Thanks also for your advice with vfdmod I will have a look on this. The first impression looks a bit cleaner and easier to understand than md2hal.
5 years 5 months ago #208666 by mattl
Replied by mattl on topic VFD mb2hal
Hi, I based my config for my YL620 on the one for this thread, but had some issues with it. Here is my working copy.
I also made some adjustment to my VFD Settings to help it work better at lower RPMs.
Time to create page: 0.327 seconds
