HAL multiplies but does not divide so you need to mult2 by 1.66667zajc3w wrote: Thanks.
Mux4 seems more legant way to doing it, just have to figure out syntax.
I'm beginning to think that modyfiing hy_ modbus driver might be asier than trying to understand how hal ticks...
Conversion of rpm to Hz is another one.
All need is to divide rpm by 6 and convert to integer. Can I just slap division by 6 in hal?
Todd Zuercher wrote: The spindle command speed is available in both RPM and RPS (Hz) in hal. So dividing by 60 should not be nessisary.
