Hal show not showing parport correctly.
  • jensor
  • jensor's Avatar Topic Author
  • Premium Member
  • Premium Member
29 Mar 2018 15:03 #108082 by jensor
My setup is for quadrature output, where channel is composed of A and Anot, Channel B composed of B and Bnot.
When checking Hal configuration, Pins, Parport, Hal show does not agree with measured voltages on the selected port. This shows what I get as I advance step by step on the pins that drive the x axis.
This browser does not support PDFs. Please download the PDF to view it: Download PDF
I've attached the appropriate ini and Hal files of concern The crazy thing is it works as configured. If something breaks and I need to fix it, I need to understand what is going on.
29 Mar 2018 21:20 #108090 by tommylight
Replied by tommylight on topic Hal show not showing parport correctly.
Paralel port does not have differential inputs for encoders, so just A and B will do fine, you do not need to connect Anot and Bnot.
  • jensor
  • Premium Member
  • Premium Member
30 Mar 2018 05:35 #108098 by jensor
Replied by jensor on topic Hal show not showing parport correctly.
My motor drivers do require differential input and if you look at my hal file you will see it is configured for the differential output.
30 Mar 2018 07:03 #108103 by BigJohnT
Replied by BigJohnT on topic Hal show not showing parport correctly.
I don't see where you loaded a stepgen to generate the pulses...
JT
  • jensor
  • Premium Member
  • Premium Member
30 Mar 2018 19:52 #108158 by jensor
See the the attached 1BPstepper.hal and 2x-BoxPinOut.hal which are called in my ini.
File Name: 1BPstepper.hal
File Size:2 KB
File Name: 2X-BoxPinO...3-30.hal
File Size:5 KB
30 Mar 2018 20:48 #108159 by tommylight
Hmmmmm my bad, thought you had them as inputs.
net X_phaseA => parport.1.pin-07-out
net X_phaseA => parport.1.pin-08-out
setp parport.1.pin-08-out-invert TRUE <
try 1 instead of true
net X_phaseB => parport.1.pin-05-out
net X_phaseB => parport.1.pin-06-out
setp parport.1.pin-06-out-invert TRUE
Try the above, i know for sure it works on my configs.
Time to create page: 0.232 seconds
