I cannot Un-Emergancy Stop [X] or Press Power [ | ] in Linux CNC
- BrendaEM
- Thank you received: 120
09 May 2018 22:05 - 10 May 2018 00:32 #110486
by BrendaEM
I cannot Un-Emergancy Stop [X] or Press Power [ | ] in Linux CNC was created by BrendaEM
I cannot seem to un-press LinuxCNC (In Axis GUI) screen Emergency Stop [X] to turn on screen Power Button [ | ] to start the machine for manual control. I tried pressing [F1] and [F2] quite a bit, with no change. The limit switches work, and are not in a tripped state when I am trying to start it.
I suspect that it's the estop config in the .hal is holding it back.
I've seen threads on estop hal settings, but it's really hard to know when the example needs correction and it's not quite what I want to do.
My setup is a parallel port isolator card. Tempoarily, I just have a wire jumping the terminals p13 to GND to simulate a NC switch.
What I want to do (in the final setup) is use a hardware switch to do an softer emergency-stop stopping LinuxCNC/Axis.
I have not need to send any signals out to hardware--only to tell the GUI to flip the GUI Estop, and stop banging out additional steps.
(I also have a hardware real e-stop, which opens a relay killing the power to the drivers and (future) spindle, yet I want to use a soft-emergency switch, with the hardware the relay switch if all else goes wrong.)
According to the hall utility, the signal is reporting FALSE. Actually, I tried it both ways. The board is doing its job reading the...um...wire bridge.
I suspect I have something wrong with the .hal. The estop section was initially prepared by stepconf. I changed a name, but in two places, which changed nothing, as well.
I thought the problem might be that I wasn't sending the signal out to any pin in the 2nd line. I tried commenting it out, but there was no change, either.
These are the current estop-lines:
net estop-in <= parport.0.pin-13-in
(skipping further down...)
net estop-in => iocontrol.0.emc-enable-in
[My setup is otherwise strange because I have step-up step-down drivers, but I don't think that that's the problem, because I can't even disengauge the screen Emergancy Stop [X] button, yet.
REF: forum.linuxcnc.org/16-stepconf-wizard/34...tion?start=10#110484]
Thanks for reading this far : )
Brenda
Ref:
www.forum.linuxcnc.org/forum/21-axis/293...machine-power-toggle
www.forum.linuxcnc.org/47-hal-examples/25861-external-e-stop
www.forum.linuxcnc.org/47-hal-examples/28096-estop-latch
Brenda
Ref:
Last edit: 10 May 2018 00:32 by BrendaEM.
- Thank you received: 1482
10 May 2018 08:09 #110508
Replied by Todd Zuercher on topic I cannot Un-Emergancy Stop [X] or Press Power [ | ] in Linux CNC
The pin " iocontrol.0.emc-enable-in" needs to be driven true for the machine to come out of E-stop.
- BrendaEM
10 May 2018 12:37 #110528
by BrendaEM
Replied by BrendaEM on topic I cannot Un-Emergancy Stop [X] or Press Power [ | ] in Linux CNC
Thank you : )
- vsjadhav
01 Jun 2019 03:23 #135550
by vsjadhav
Replied by vsjadhav on topic I cannot Un-Emergancy Stop [X] or Press Power [ | ] in Linux CNC
I got the same problem.
What does it mean by "needs to be driven true"
Is it related to changes in .ini
Or
It's about hardware must be connected
Or
- bevins
- Thank you received: 338
01 Jun 2019 06:43 #135557
by bevins
Put this in your hal file.
Replied by bevins on topic I cannot Un-Emergancy Stop [X] or Press Power [ | ] in Linux CNC
Or
loadrt estop_latch
addf estop-latch.0 servo-thread
net estop-loopout iocontrol.0.emc-enable-in <= estop-latch.0.ok-out
net estop-loopin iocontrol.0.user-enable-out => estop-latch.0.ok-in
net estop-reset iocontrol.0.user-request-enable => estop-latch.0.reset
net remote-estop estop-latch.0.fault-in <= <Your input goes here>Please Log in or Create an account to join the conversation.
Time to create page: 0.078 seconds
