Help in understanding Hal -d setting to VFD
13 Jun 2018 19:33 #112316 by andypugh
Replied by andypugh on topic Help in understanding Hal -d setting to VFD
if "device=" worked before then I am puzzled why it stopped working.
One possibility is that something (like a windows editor) has introduced invisible wierd characters into the loadusr line.
13 Jun 2018 20:32 #112322 by javelin
Replied by javelin on topic Help in understanding Hal -d setting to VFD
Just an update on where things stand so at some point someone here who has this hardware can see the trail I left.
I followed the above link to go into linux and then create a symlink within linux itself, not linuxcnc. The path for the file would be /ect/udev/rules.d/filenamehere. Within that created file I made the following line creates the symlink for my usb on my machine:
KERNELS=="1-3", SUBSYSTEMS=="usb", ATTRS{idVendor}=="10c4", ATTRS{idProduct}=="ea60", SYMLINK+="ttyS0", MODE="0660"
I verified this symlink code would work by creating a test usb port which it would create with no issues. I then used the above line to link /dev/ttyUSB0 to /dev/ttyS0 .
I rebooted everything and then fired up linuxcnc. Once the software started I then went to start the spindle and nothing happened. For some reason this still is not working.
Aside from the settings within the vfd I even went as far as using stty -F /dev/ttyUSB0 9600 and then also editing my hal file loadusr line to accept the device="/dev/ttyUSB0" in hopes that it was simply a failure in communication there but still no start on the spindle.
I will begin to prepare to wire this thing in through TB4 on the 7i76. I have about exhausted the limits of my abilities on this one. If anyone out there is using the Hitachi WJ200 with a rs485 feel free to give a shout to me so I can see what you have done.
Thanks for all the help Andy, it was worth the go. I may revisit this later. If I do and find any success I will let you guys know.
13 Jun 2018 20:34 #112323 by javelin
Running Linux Mint nothing windows related on my end or do you mean on the end where this was compiled?
14 Jun 2018 16:05 #112359 by andypugh
Is it worth seeing if you have more than one version of the module on your PC?
(It might even be worth re-compiling the module)
18 Jun 2018 23:01 #112561 by javelin
Sorry Ive been out of town for a few days.
Only one module yet I may try to recompile it at some point. That would take some serious effort as it is a bit outside of my scope of knowledge at the moment. Im game for trying it though.
Right now I am sorting out hooking it up through TB4. If I determine I do not like this method I may do exactly as you said. Yet for the moment I want the machine running to get me to the next stage.
If I need to I will buy another Huanyang as I really like the modbus configuration then figure out the recompile for the wj200. I really would love the wj200 on modbus so that is the goal in the end no matter what. For me its not a waste of money to have a cheaper backup as I always want backups on hand. I am that way with everything, especially electronics. I fly FPV acro drones, let me tell you it really sucks to not have the parts on hand after a crash LOL!
Time to create page: 0.187 seconds
