Reduce power to steppers when not moving
- Ralf
12 Aug 2018 09:41 #115962
by Ralf
Reduce power to steppers when not moving was created by Ralf
Is it possible to assign a pin that is only active when a move is done?
If possible I would like to utilize my drivers "power down" function, which reduces power to the steppers when full power is not needed, i.e. when the mill just sits idle, but still needs to maintain it's position.
- Thank you received: 5336
12 Aug 2018 13:01 - 12 Aug 2018 13:03 #115979
Replied by PCW on topic Reduce power to steppers when not moving
One way is to feed motion.current.vel into the "near" component and then use the output of near to set the drives to low power mode when the velocity is zero or very close to 0 , something like:
loadrt near
addf near.0 servo-thread
setp near.0.in2 0
setp near.0.difference 0.00001
net velocity motion.current-vel => near.0.in1
net zerovel near.0.out => PinToEnableLowPowerMode
loadrt near
setp near.0.in2 0
Last edit: 12 Aug 2018 13:03 by PCW.
The following user(s) said Thank You: tivoi, Ralf
- Ralf
13 Aug 2018 02:17 #115990
by Ralf
Replied by Ralf on topic Reduce power to steppers when not moving
Thanks, I actually think that I understand what's going on there..
Will test out tonight..
If I want to add a hysteresis to prevent powerdown from flickering up and down, could I abuse the debounce component, combined with an or gate like this ?
I would assume that the or gate would be needed, since the debounce seems to work in both directions, and would would cause a delay before the steppers would be enabled on move, if wired directly to the output.
Or does a timer module exists, with a simple countdown function, instead of using debounce?
And where would I put all of this, custom.hal or custom_postgui.hal?
loadrt near
setp near.0.in2 0
loadrt debounce cfg=1
addf debounce.0 servo-thread
setp debounce.0.delay 1000
net debounce-in <= near.0.out => debounce.0.0.in
loadrt or2
addf or2.0 servo-thread
net powerdown-1 or2.0.in0 <= near.0.out
net powerdown-2 or2.0.in1 <= debounce.0.0.out
net powerdown or2.0.out => PinToEnableLowPowerModeI would assume that the or gate would be needed, since the debounce seems to work in both directions, and would would cause a delay before the steppers would be enabled on move, if wired directly to the output.
- Mike_Eitel
- Thank you received: 183
13 Aug 2018 10:40 #116008
by Mike_Eitel
Replied by Mike_Eitel on topic Reduce power to steppers when not moving
Use OR plus ONESHOT in parallel to rise current. OR in0 for moving and OR in1 for delayed reduziert
Mike
Mike
The following user(s) said Thank You: Ralf
- Ralf
13 Aug 2018 23:34 #116021
by Ralf
Oneshot seem to do the trick, together with velocity.
The following works out nicely in halscope.
loadrt near
setp near.0.in2 0
setp near.0.difference 0.0000001
loadrt not
addf not.0 servo-thread
net moving not.0.in <= near.0.out
loadrt oneshot
addf oneshot.0 servo-thread
setp oneshot.0.width 1
setp oneshot.0.rising TRUE
setp oneshot.0.falling TRUE
setp oneshot.0.retriggerable TRUE
net moving oneshot.0.in <= near.0.out
loadrt or2
net moving-inv or2.0.in0 <= not.0.out
net powerdown-2 or2.0.in1 <= oneshot.0.out
net powerdown parport.0.pin-08-out <= or2.0.outPlease Log in or Create an account to join the conversation.
