Solved - Endstop error after setting HOME SEQUENCE 0-1-1
15 Aug 2018 12:01 - 18 Oct 2018 09:36 #116088 by caban
As long as I have the homing sequence on 0-1-2 everything is ok.
If I change it to 0-1-1 comes an Endstop error message.
Does anyone know advice?
Last edit: 18 Oct 2018 09:36 by caban.
16 Aug 2018 08:02 #116137 by andypugh
Do both "1" axes share a limit switch input?
There are INI file entries for "HOME_IGNORE_LIMIT" and "HOME_IS_SHARED" that might need to be set.
linuxcnc.org/docs/2.7/html/config/ini-co...s__lt_num_gt_section
16 Aug 2018 08:11 #116139 by caban
No, every axis has its own switch and its own input pin..
16 Aug 2018 08:25 #116147 by andypugh
Is the home switch also the limit switch? If it is then you do need HOME_IGNORE_LIMITS
But I think that there might be a bit of a bug where the system only ignores some limits if more than one axis is moving. Pnnconf seems to do some clever stuff with a lut5 component to get round this (I am fuzzy on the details here)
16 Aug 2018 11:51 #116176 by Mike_Eitel
Replied by Mike_Eitel on topic Endstop error after setting HOME SEQUENCE 0-1-1
I remember from Stuttgart that setting the HOME positions uneven to 0.0 to release the switches was part of the solution.
Mike
The following user(s) said Thank You: caban
18 Oct 2018 09:36 #118998 by caban
Relocating the home position from the switch solved the problem
Time to create page: 0.127 seconds
