Secondary Spindle HAL integration
- dberndt
14 Oct 2018 23:28 #118818
by dberndt
Secondary Spindle HAL integration was created by dberndt
I've recently stuck a router spindle on my Mill to provide some higher spindle speeds when running tiny tools. Seems to work well. Looking for ways to integrate it more fully into HAL. I've got it on a relay controlled circuit, and have an amp meter wired in, my thought is to use the current draw as some indication that the spindle is on/spinning and therefore "at speed".
But more importantly I'd like to get the logic for which spindle to turn on in place. I'm thinking currently of basing it on tool number, say tools > 100 = use subspindle. I'd also like to inhibit the main spindle in this scenario, the main spindle doesn't appreciate being spun up accidentally without a tool in it, and it scares the crap out of me every time...
I don't really have enough HAL experience to understand if that's a reasonable idea or a bad idea instead of trying to get the new master versions that seem to have some sort of multi spindle support. Open to any suggestions.
I guess if it's a tool based approach, or even just an a custom M code? it'd have to do something like re-net: motion.spindle-forward, motion.spindle.reverse, motion-spindle-on, motion-spindle-at-speed, motion.spindle-speed.out, maybe a few others of the same type and that'd be about it?
Thanks,
Dave
Thanks,
Dave
- Thank you received: 1482
15 Oct 2018 09:50 #118834
Replied by Todd Zuercher on topic Secondary Spindle HAL integration
On the multi spindle routers I've set up I've always done it with custom M-codes to choose which spindle(s) receive the run command signals. I'll post an example config if you'd like to see how I implemented it.
- Thank you received: 2181
15 Oct 2018 15:12 #118842
Replied by cmorley on topic Secondary Spindle HAL integration
In master now there is builtin support for multiple spindles.
The bugs are still being squeezed out but Thanks to Andy eventually this will be much easier.
Chris M
Chris M
17 Oct 2018 07:58 #118939
Replied by andypugh on topic Secondary Spindle HAL integration
linuxcnc.org/docs/devel/html/man/man9/motion.9.html
Lists the new spindle pin layout. But needs to be edited to add the new num_spindles parameter to the motion module.
I need to update the G-code docs to reflect the new syntax.
Any existing programs will work as before without modification.
Basically S100 or S100 $0 will set the speed of spindle 0
S100 $1 sets the speed of spindle 1
M3 starts all spindles at their set speed
M3 $3 starts only spindle 3]
M5 stops all spindles
M5 $2 stops only spindle 2.
G76 ..... $1 does lathe threading synched to the spindle.1.revs HAL pin.
The following user(s) said Thank You: kentavv
Time to create page: 0.206 seconds
