Message Component - Reset?
7 years 3 months ago #140150 by phillc54
Replied by phillc54 on topic Message Component - Reset?
You would need to net the axisui.notifications-clear pin in the postgui halfile
The following user(s) said Thank You: DeckelHead
7 years 3 months ago #140186 by DeckelHead
Ah! That makes sense... I had looked at ordering in my INI file, but I didn't even consider that the GUI had a postgui HAL file. I'll try that.... Thanks for the heads up!
6 years 10 months ago - 6 years 9 months ago #152272 by chimeno
Replied by chimeno on topic Message Component - Reset?
Hi, I found this old thread, and I'm looking for a HAL pin output that notifies me when a message appears in the AXIS guide, any idea if it exists? does not exist.
I have to create a new output pin, I must look at the file
./src/emc/usr_intf/axis/scripts
if hal_present == 1:     comp = hal.component ("axisui")     comp.newpin ("jog.x", hal.HAL_BIT, hal.HAL_OUT)     comp.newpin ("jog.y", hal.HAL_BIT, hal.HAL_OUT)     comp.newpin ("jog.z", hal.HAL_BIT, hal.HAL_OUT)     comp.newpin ("jog.a", hal.HAL_BIT, hal.HAL_OUT)     comp.newpin ("jog.b", hal.HAL_BIT, hal.HAL_OUT)     comp.newpin ("jog.c", hal.HAL_BIT, hal.HAL_OUT)     comp.newpin ("jog.u", hal.HAL_BIT, hal.HAL_OUT)     comp.newpin ("jog.v", hal.HAL_BIT, hal.HAL_OUT)     comp.newpin ("jog.w", hal.HAL_BIT, hal.HAL_OUT)     comp.newpin ("jog.increment", hal.HAL_FLOAT, hal.HAL_OUT)     comp.newpin ("notifications-out", hal.HAL_BIT, hal.HAL_OUT)     comp.newpin ("notifications-clear", hal.HAL_BIT, hal.HAL_IN)     comp.newpin ("notifications-clear-info", hal.HAL_BIT, hal.HAL_IN)     comp.newpin ("notifications-clear-error", hal.HAL_BIT, hal.HAL_IN)     comp.newpin ("resume-inhibit", hal.HAL_BIT, hal.HAL_IN)
added this line
now I must connect it, I guess I should look at the
class Notification (Tkinter.Frame):
but I don't have much experience in phyton, if someone can guide me or help me ?, thanks
greeting
Chimeno
Last edit: 6 years 9 months ago by chimeno. Reason: more information
6 years 9 months ago #154007 by chimeno
Hello again,
I am trying that when an error message occurs to be able to activate an output pin, warning, I think it would be good for linuxcnc, now I have it worked as I show in the image img2477, but when I close the application an error appears, I will not program python so I'm trying, if someone can tell me what I did wrong or how I should do it, the changes are in this fil
./src/emc/usr_intf/axis/scripts/axis.py
the lines that added
comp ['notifications'] = False
comp ["notifications"] = True
comp.newpin ("notifications", hal.HAL_BIT, hal.HAL_OUT)
in which section:
 def remove (self, widgets):         self.widgets.remove (widgets)         if len (self.cache) <10:             widgets [0] .pack_forget ()             self.cache.append (widgets)         else:             widgets [0] .destroy ()         if len (self.widgets) == 0:             self.place_forget ()             comp ['notifications'] = False   def error_task (self):         error = e.poll ()         while error:             kind, text = error             if kind in (linuxcnc.NML_ERROR, linuxcnc.OPERATOR_ERROR):                 icon = "error"             else:                 icon = "info"             notifications.add (icon, text)             comp ["notifications"] = True             error = e.poll ()         self.error_after = self.win.after (200, self.error_task) if hal_present == 1:     comp = hal.component ("axisui")     comp.newpin ("jog.x", hal.HAL_BIT, hal.HAL_OUT)     comp.newpin ("jog.y", hal.HAL_BIT, hal.HAL_OUT)     comp.newpin ("jog.z", hal.HAL_BIT, hal.HAL_OUT)     comp.newpin ("jog.a", hal.HAL_BIT, hal.HAL_OUT)     comp.newpin ("jog.b", hal.HAL_BIT, hal.HAL_OUT)     comp.newpin ("jog.c", hal.HAL_BIT, hal.HAL_OUT)     comp.newpin ("jog.u", hal.HAL_BIT, hal.HAL_OUT)     comp.newpin ("jog.v", hal.HAL_BIT, hal.HAL_OUT)     comp.newpin ("jog.w", hal.HAL_BIT, hal.HAL_OUT)     comp.newpin ("jog.increment", hal.HAL_FLOAT, hal.HAL_OUT)     comp.newpin ("notifications-clear", hal.HAL_BIT, hal.HAL_IN)     comp.newpin ("notifications-clear-info", hal.HAL_BIT, hal.HAL_IN)     comp.newpin ("notifications-clear-error", hal.HAL_BIT, hal.HAL_IN)     comp.newpin ("resume-inhibit", hal.HAL_BIT, hal.HAL_IN)     comp.newpin ("notifications", hal.HAL_BIT, hal.HAL_OUT)
greeting
Chimeno
6 years 9 months ago #154074 by phillc54
You will get that error if you have the HAL Configuration window open while Axis is exiting. The error is because HAL Configuration cannot find the pin because it was removed by Axis when it was exiting.
You could also achieve the same with the following in the .axisrc file in your home directory which allows you to update LinuxCNC without have to edit axis.py again.
def user_hal_pins(): comp.newpin('notifications', hal.HAL_BIT, hal.HAL_OUT) comp.ready() def user_live_update(): if len(notifications.widgets): comp ["notifications"] = True else: comp ["notifications"] = False
You could have a USER_COMMAND_FILE instead of .axisrc.
See sections 12.3, 12.4, 12.5 & 12.6 here: linuxcnc.org/docs/devel/html/gui/axis.html#_axisrc
The following user(s) said Thank You: chimeno
6 years 9 months ago #154235 by chimeno
Hi Phill,
  Thank you very much for the answer, modify the code because the .axisrc file does not work for me, it is in the directory where I have the configuration files .ini and .hal, formerly if it worked for me, something else I should do, anyway add your code via USER_COMMAND_FILE and it works very well, I admire your work here in the forum!
thanks
Chimeno
Time to create page: 0.132 seconds
