7i76 to software mode 2
17 Nov 2018 07:37 #120898 by MaHo
7i76 to software mode 2 was created by MaHo
Hello guys,
Here is the case. I have a 5i25&7i76 card on my machine and everything is running fine, except...
Now i want to add a MPG handwheel. So i want to hook it up on to input 16 and 17 (A&B) and steel the 5v from TB3 1 and 6.
Then i want change the card to mode 2.
OK lets do that change sserial_port_0=00xxxx to sserial_port_0=20xxxx
But then when i start up Linuxcnc i get 2 messages:
hm/2hm2_5i25.0: ***Smart Serial Port 0 will be stopped***
and
hm/2hm2_5i25.0: Smart Serial Comms Error: There have been more then 1 errors in 10 thread executions at least 200 times. See other error messages for details.
I tried some other variations like sserial_port_0=2xxxx, sserial_port_0=2xxxxxxx sserial_port_0=20xxxxxxx
but resultsin the same
Any suggestions are really appreciated.
Mark
17 Nov 2018 10:00 #120901 by alan_3301
Replied by alan_3301 on topic 7i76 to software mode 2
try sserial_port_0=200xxx
17 Nov 2018 11:26 #120911 by MaHo
Replied by MaHo on topic 7i76 to software mode 2
Helo Alan, thanks for the reply.
I just tried it.
But... no luck...
Mark
17 Nov 2018 12:11 #120914 by PCW
Replied by PCW on topic 7i76 to software mode 2
That sounds like some other error unrelated to the 7I76's mode,
can you post your hal/ini files here?
Any of those mode set lines should be OK
17 Nov 2018 12:52 - 17 Nov 2018 12:52 #120915 by MaHo
when i just keep it in mode 0, there is no error and everything works fine.
But here my Hal:
# Generated by PNCconf at Sat Nov 17 15:15:18 2018
# overwritten when you run PNCconf again
loadrt trivkins
loadrt [EMCMOT]EMCMOT servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[TRAJ]AXES
loadrt hostmot2
loadrt hm2_pci config=" num_encoders=0 num_pwmgens=0 num_stepgens=3 sserial_port_0=200xxx"
setp    hm2_5i25.0.watchdog.timeout_ns 5000000
loadrt pid names=pid.x,pid.y,pid.z,pid.s
addf hm2_5i25.0.read          servo-thread
addf motion-command-handler   servo-thread
addf motion-controller        servo-thread
addf pid.x.do-pid-calcs       servo-thread
addf pid.y.do-pid-calcs       servo-thread
addf pid.z.do-pid-calcs       servo-thread
addf pid.s.do-pid-calcs       servo-thread
addf hm2_5i25.0.write         servo-thread
# external output signals
# --- COOLANT-FLOOD ---
net coolant-flood hm2_5i25.0.7i76.0.0.output-09
# external input signals
# --- HOME-X ---
net home-x     <=  hm2_5i25.0.7i76.0.0.input-01
# --- HOME-Y ---
net home-y     <=  hm2_5i25.0.7i76.0.0.input-02-not
# --- HOME-Z ---
net home-z     <=  hm2_5i25.0.7i76.0.0.input-03
# --- ESTOP-EXT ---
net estop-ext     <=  hm2_5i25.0.7i76.0.0.input-04
#  AXIS X
setp   pid.x.Pgain     [AXIS_0]P
setp   pid.x.Igain     [AXIS_0]I
setp   pid.x.Dgain     [AXIS_0]D
setp   pid.x.bias      [AXIS_0]BIAS
setp   pid.x.FF0       [AXIS_0]FF0
setp   pid.x.FF1       [AXIS_0]FF1
setp   pid.x.FF2       [AXIS_0]FF2
setp   pid.x.deadband  [AXIS_0]DEADBAND
setp   pid.x.maxoutput [AXIS_0]MAX_OUTPUT
setp   pid.x.error-previous-target true
setp   pid.x.maxerror .0005
net x-index-enable  <=> pid.x.index-enable
net x-enable        =>  pid.x.enable
net x-pos-cmd       =>  pid.x.command
net x-vel-cmd       =>  pid.x.command-deriv
net x-pos-fb        =>  pid.x.feedback
net x-output        =>  pid.x.output
# Step Gen signals/setup
setp   hm2_5i25.0.stepgen.00.dirsetup        [AXIS_0]DIRSETUP
setp   hm2_5i25.0.stepgen.00.dirhold         [AXIS_0]DIRHOLD
setp   hm2_5i25.0.stepgen.00.steplen         [AXIS_0]STEPLEN
setp   hm2_5i25.0.stepgen.00.stepspace       [AXIS_0]STEPSPACE
setp   hm2_5i25.0.stepgen.00.position-scale  [AXIS_0]STEP_SCALE
setp   hm2_5i25.0.stepgen.00.step_type        0
setp   hm2_5i25.0.stepgen.00.control-type     1
setp   hm2_5i25.0.stepgen.00.maxaccel         [AXIS_0]STEPGEN_MAXACCEL
setp   hm2_5i25.0.stepgen.00.maxvel           [AXIS_0]STEPGEN_MAXVEL
# ---closedloop stepper signals---
net x-pos-cmd    <= axis.0.motor-pos-cmd
net x-vel-cmd    <= axis.0.joint-vel-cmd
net x-output     <= hm2_5i25.0.stepgen.00.velocity-cmd
net x-pos-fb     <= hm2_5i25.0.stepgen.00.position-fb
net x-pos-fb     => axis.0.motor-pos-fb
net x-enable     <= axis.0.amp-enable-out
net x-enable     => hm2_5i25.0.stepgen.00.enable
# ---setup home / limit switch signals---
net home-x     =>  axis.0.home-sw-in
net x-neg-limit     =>  axis.0.neg-lim-sw-in
net x-pos-limit     =>  axis.0.pos-lim-sw-in
#  AXIS Y
setp   pid.y.Pgain     [AXIS_1]P
setp   pid.y.Igain     [AXIS_1]I
setp   pid.y.Dgain     [AXIS_1]D
setp   pid.y.bias      [AXIS_1]BIAS
setp   pid.y.FF0       [AXIS_1]FF0
setp   pid.y.FF1       [AXIS_1]FF1
setp   pid.y.FF2       [AXIS_1]FF2
setp   pid.y.deadband  [AXIS_1]DEADBAND
setp   pid.y.maxoutput [AXIS_1]MAX_OUTPUT
setp   pid.y.error-previous-target true
setp   pid.y.maxerror .0005
net y-index-enable  <=> pid.y.index-enable
net y-enable        =>  pid.y.enable
net y-pos-cmd       =>  pid.y.command
net y-vel-cmd       =>  pid.y.command-deriv
net y-pos-fb        =>  pid.y.feedback
net y-output        =>  pid.y.output
setp   hm2_5i25.0.stepgen.01.dirsetup        [AXIS_1]DIRSETUP
setp   hm2_5i25.0.stepgen.01.dirhold         [AXIS_1]DIRHOLD
setp   hm2_5i25.0.stepgen.01.steplen         [AXIS_1]STEPLEN
setp   hm2_5i25.0.stepgen.01.stepspace       [AXIS_1]STEPSPACE
setp   hm2_5i25.0.stepgen.01.position-scale  [AXIS_1]STEP_SCALE
setp   hm2_5i25.0.stepgen.01.step_type        0
setp   hm2_5i25.0.stepgen.01.control-type     1
setp   hm2_5i25.0.stepgen.01.maxaccel         [AXIS_1]STEPGEN_MAXACCEL
setp   hm2_5i25.0.stepgen.01.maxvel           [AXIS_1]STEPGEN_MAXVEL
net y-pos-cmd    <= axis.1.motor-pos-cmd
net y-vel-cmd    <= axis.1.joint-vel-cmd
net y-output     <= hm2_5i25.0.stepgen.01.velocity-cmd
net y-pos-fb     <= hm2_5i25.0.stepgen.01.position-fb
net y-pos-fb     => axis.1.motor-pos-fb
net y-enable     <= axis.1.amp-enable-out
net y-enable     => hm2_5i25.0.stepgen.01.enable
net home-y     =>  axis.1.home-sw-in
net y-neg-limit     =>  axis.1.neg-lim-sw-in
net y-pos-limit     =>  axis.1.pos-lim-sw-in
#  AXIS Z
setp   pid.z.Pgain     [AXIS_2]P
setp   pid.z.Igain     [AXIS_2]I
setp   pid.z.Dgain     [AXIS_2]D
setp   pid.z.bias      [AXIS_2]BIAS
setp   pid.z.FF0       [AXIS_2]FF0
setp   pid.z.FF1       [AXIS_2]FF1
setp   pid.z.FF2       [AXIS_2]FF2
setp   pid.z.deadband  [AXIS_2]DEADBAND
setp   pid.z.maxoutput [AXIS_2]MAX_OUTPUT
setp   pid.z.error-previous-target true
setp   pid.z.maxerror .0005
net z-index-enable  <=> pid.z.index-enable
net z-enable        =>  pid.z.enable
net z-pos-cmd       =>  pid.z.command
net z-vel-cmd       =>  pid.z.command-deriv
net z-pos-fb        =>  pid.z.feedback
net z-output        =>  pid.z.output
setp   hm2_5i25.0.stepgen.02.dirsetup        [AXIS_2]DIRSETUP
setp   hm2_5i25.0.stepgen.02.dirhold         [AXIS_2]DIRHOLD
setp   hm2_5i25.0.stepgen.02.steplen         [AXIS_2]STEPLEN
setp   hm2_5i25.0.stepgen.02.stepspace       [AXIS_2]STEPSPACE
setp   hm2_5i25.0.stepgen.02.position-scale  [AXIS_2]STEP_SCALE
setp   hm2_5i25.0.stepgen.02.step_type        0
setp   hm2_5i25.0.stepgen.02.control-type     1
setp   hm2_5i25.0.stepgen.02.maxaccel         [AXIS_2]STEPGEN_MAXACCEL
setp   hm2_5i25.0.stepgen.02.maxvel           [AXIS_2]STEPGEN_MAXVEL
net z-pos-cmd    <= axis.2.motor-pos-cmd
net z-vel-cmd    <= axis.2.joint-vel-cmd
net z-output     <= hm2_5i25.0.stepgen.02.velocity-cmd
net z-pos-fb     <= hm2_5i25.0.stepgen.02.position-fb
net z-pos-fb     => axis.2.motor-pos-fb
net z-enable     <= axis.2.amp-enable-out
net z-enable     => hm2_5i25.0.stepgen.02.enable
net home-z     =>  axis.2.home-sw-in
net z-neg-limit     =>  axis.2.neg-lim-sw-in
net z-pos-limit     =>  axis.2.pos-lim-sw-in
#  SPINDLE S
setp   pid.s.Pgain     [SPINDLE_9]P
setp   pid.s.Igain     [SPINDLE_9]I
setp   pid.s.Dgain     [SPINDLE_9]D
setp   pid.s.bias      [SPINDLE_9]BIAS
setp   pid.s.FF0       [SPINDLE_9]FF0
setp   pid.s.FF1       [SPINDLE_9]FF1
setp   pid.s.FF2       [SPINDLE_9]FF2
setp   pid.s.deadband  [SPINDLE_9]DEADBAND
setp   pid.s.maxoutput [SPINDLE_9]MAX_OUTPUT
setp   pid.s.error-previous-target true
net spindle-index-enable  <=> pid.s.index-enable
net spindle-enable        =>  pid.s.enable
net spindle-vel-cmd-rpm-abs     => pid.s.command
net spindle-vel-fb-rpm-abs      => pid.s.feedback
net spindle-output        <=  pid.s.output
# ---digital potentionmeter output signals/setup---
setp   hm2_5i25.0.7i76.0.0.spinout-minlim    [SPINDLE_9]OUTPUT_MIN_LIMIT
setp   hm2_5i25.0.7i76.0.0.spinout-maxlim    [SPINDLE_9]OUTPUT_MAX_LIMIT
setp   hm2_5i25.0.7i76.0.0.spinout-scalemax  [SPINDLE_9]OUTPUT_SCALE
net spindle-output      => hm2_5i25.0.7i76.0.0.spinout
net spindle-enable      => hm2_5i25.0.7i76.0.0.spinena
net spindle-ccw         => hm2_5i25.0.7i76.0.0.spindir
net spindle-vel-cmd-rps        <=  motion.spindle-speed-out-rps
net spindle-vel-cmd-rps-abs    <=  motion.spindle-speed-out-rps-abs
net spindle-vel-cmd-rpm        <=  motion.spindle-speed-out
net spindle-vel-cmd-rpm-abs    <=  motion.spindle-speed-out-abs
net spindle-enable             <=  motion.spindle-on
net spindle-cw                 <=  motion.spindle-forward
net spindle-ccw                <=  motion.spindle-reverse
net spindle-brake              <=  motion.spindle-brake
net spindle-revs               =>  motion.spindle-revs
net spindle-at-speed           =>  motion.spindle-at-speed
net spindle-vel-fb-rps         =>  motion.spindle-speed-in
net spindle-index-enable      <=>  motion.spindle-index-enable
sets spindle-at-speed true
# connect miscellaneous signals
#  ---HALUI signals---
net joint-select-a        halui.joint.0.select
net x-is-homed            halui.joint.0.is-homed
net jog-x-pos             halui.jog.0.plus
net jog-x-neg             halui.jog.0.minus
net jog-x-analog          halui.jog.0.analog
net joint-select-b        halui.joint.1.select
net y-is-homed            halui.joint.1.is-homed
net jog-y-pos             halui.jog.1.plus
net jog-y-neg             halui.jog.1.minus
net jog-y-analog          halui.jog.1.analog
net joint-select-c        halui.joint.2.select
net z-is-homed            halui.joint.2.is-homed
net jog-z-pos             halui.jog.2.plus
net jog-z-neg             halui.jog.2.minus
net jog-z-analog          halui.jog.2.analog
net jog-selected-pos      halui.jog.selected.plus
net jog-selected-neg      halui.jog.selected.minus
net spindle-manual-cw     halui.spindle.forward
net spindle-manual-ccw    halui.spindle.reverse
net spindle-manual-stop   halui.spindle.stop
net machine-is-on         halui.machine.is-on
net jog-speed             halui.jog-speed
net MDI-mode              halui.mode.is-mdi
#  ---coolant signals---
net coolant-mist      <=  iocontrol.0.coolant-mist
net coolant-flood     <=  iocontrol.0.coolant-flood
#  ---probe signal---
net probe-in     =>  motion.probe-input
#  ---motion control signals---
net in-position               <=  motion.in-position
net machine-is-enabled        <=  motion.motion-enabled
#  ---digital in / out signals---
#  ---estop signals---
net estop-out     <=  iocontrol.0.user-enable-out
net estop-ext     =>  iocontrol.0.emc-enable-in
#  ---manual tool change signals---
net tool-change-request     iocontrol.0.tool-change       =>  hal_manualtoolchange.change
net tool-change-confirmed   iocontrol.0.tool-changed      <=  hal_manualtoolchange.changed
net tool-number             iocontrol.0.tool-prep-number  =>  hal_manualtoolchange.number
net tool-prepare-loopback   iocontrol.0.tool-prepare      =>  iocontrol.0.tool-prepared
and the custom.hal
# Include your custom HAL commands here
# This file will not be overwritten when you run PNCconf again
#central lubrication
loadrt lubrication
addf lubrication.0 servo-thread
net lube lubrication.0.lube => hm2_5i25.0.7i76.0.0.output-08
net motion lubrication.0.motion <= motion.current-vel
net lubelow lubrication.0.lubelow <= hm2_5i25.0.7i76.0.0.input-16
#loadrt time
#loadusr -W lube.py
#addf lube servo-thread
#net lube-run lube.run => hm2_5i25.0.7i76.0.0.output-08
#net machine-is-enabled lube.machine_status <= motion.motion-enabled
#net spindle-on lube.spindle_status
#net lube-ps-float-sw lube.pressuresw_floatsw <= hm2_5i25.0.7i76.0.0.input-15
and the INI:
# Generated by PNCconf at Mon Sep 24 09:22:53 2018
[EMC]
MACHINE = MAHOCNC
DEBUG = 0
[DISPLAY]
DISPLAY = gmoccapy
POSITION_OFFSET = RELATIVE
POSITION_FEEDBACK = ACTUAL
MAX_FEED_OVERRIDE = 2.000000
MAX_SPINDLE_OVERRIDE = 1.000000
MIN_SPINDLE_OVERRIDE = 0.500000
INTRO_TIME = 5
PROGRAM_PREFIX = /home/mark/linuxcnc/nc_files
INCREMENTS = 5mm 1mm .5mm .1mm .05mm .01mm .005mm
DEFAULT_LINEAR_VELOCITY = 6.000000
MAX_LINEAR_VELOCITY = 25.000000
MIN_LINEAR_VELOCITY = 0.500000
DEFAULT_ANGULAR_VELOCITY = 12.000000
MAX_ANGULAR_VELOCITY = 180.000000
MIN_ANGULAR_VELOCITY = 1.666667
EDITOR = gedit
GEOMETRY = xyz
[FILTER]
png = image-to-gcode
gif = image-to-gcode
jpg = image-to-gcode
py = python
[TASK]
TASK = milltask
CYCLE_TIME = 0.010
[RS274NGC]
PARAMETER_FILE = linuxcnc.var
[EMCMOT]
EMCMOT = motmod
COMM_TIMEOUT = 1.0
COMM_WAIT = 0.010
SERVO_PERIOD = 100000
[HOSTMOT2]
# **** This is for info only ****
# DRIVER0=hm2_pci
# BOARD0=5i25
[HAL]
HALUI = halui
HALFILE = MAHOCNC.hal
HALFILE = custom.hal
POSTGUI_HALFILE = postgui_call_list.hal
SHUTDOWN = shutdown.hal
[HALUI]
[TRAJ]
AXES = 3
COORDINATES = X Y Z
LINEAR_UNITS = mm
ANGULAR_UNITS = degree
CYCLE_TIME = 0.010
DEFAULT_VELOCITY = 2.50
NO_FORCE_HOMING = 1
[EMCIO]
EMCIO = io
CYCLE_TIME = 0.100
TOOL_TABLE = tool.tbl
TOOL_CHANGE_QUILL_UP = 1
# Axis X
[AXIS_0]
TYPE = LINEAR
HOME = 170.0
FERROR = 10.0
MIN_FERROR = 1.0
MAX_VELOCITY = 25.0
MAX_ACCELERATION = 750.0
STEPGEN_MAXVEL = 31.25
STEPGEN_MAXACCEL = 937.50
P = 10000.0
I = 0.0
D = 0.0
FF0 = 0.0
FF1 = 1.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 0.0
# these are in nanoseconds
DIRSETUP   = 5000
DIRHOLD    = 5000
STEPLEN    = 2500
STEPSPACE  = 2500
STEP_SCALE = 400.0
MIN_LIMIT = -0.0
MAX_LIMIT = 340.0
HOME_OFFSET = 68.000000
HOME_SEARCH_VEL = -2.000000
HOME_LATCH_VEL = -0.500000
HOME_FINAL_VEL = 0.000000
HOME_USE_INDEX = NO
HOME_SEQUENCE = 1
# Axis Y
[AXIS_1]
TYPE = LINEAR
HOME = 160.0
FERROR = 10.0
MIN_FERROR = 1.0
MAX_VELOCITY = 25.0
P = 10000.0
I = 0.0
D = 0.0
FF0 = 0.0
FF1 = 1.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 0.0
DIRSETUP   = 5000
DIRHOLD    = 5000
STEPLEN    = 2500
STEPSPACE  = 2500
STEP_SCALE = 400.0
MIN_LIMIT = -0.01
MAX_LIMIT = 180.0
HOME_OFFSET = 46.000000
HOME_USE_INDEX = NO
HOME_SEQUENCE = 2
# Axis Z
[AXIS_2]
TYPE = LINEAR
HOME = 0.0
FERROR = 10.0
MIN_FERROR = 1.0
MAX_VELOCITY = 25.0
MAX_ACCELERATION = 500.0
STEPGEN_MAXACCEL = 625.00
P = 6000.0
I = 0.0
D = 0.0
FF0 = 0.0
FF1 = 1.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 0.0
DIRSETUP   = 5000
DIRHOLD    = 5000
STEPLEN    = 2500
STEPSPACE  = 2500
STEP_SCALE = 800.0
MIN_LIMIT = -100.0
MAX_LIMIT = 0.01
HOME_OFFSET = 0.000000
HOME_SEARCH_VEL = -1.000000
HOME_USE_INDEX = NO
HOME_SEQUENCE = 0
# Spindle
[SPINDLE_9]
P = 0
I = 0
D = 0
FF0 = 1
FF1 = 0
FF2 = 0
BIAS = 0
DEADBAND = 0
MAX_OUTPUT = 2000
I also just tested with the MPG disconnected. But till the same errors.
Last edit: 17 Nov 2018 12:52 by MaHo.
17 Nov 2018 13:42 - 17 Nov 2018 13:44 #120920 by PCW
"SERVO_PERIOD = 100000"
is WAAAAAY too fast
I would suggest 1000000 = 1 ms
Probably what is happening is that you just barely meet timing in mode 0,
and the extra data transferred in mode 2 pushes you over the edge...
Last edit: 17 Nov 2018 13:44 by PCW.
18 Nov 2018 04:44 #120936 by MaHo
Haha, That did the trick. Thanks!
But...
... I still get no counts in the hal meter.
I measure 5v on 0v to vcc
I measure 0v on a/b to 0v when i dont move and when i move the mpg the voltage goes up to aprox 3v.
do i forget something?
18 Nov 2018 06:38 #120939 by PCW
what hal pin are you watching?
18 Nov 2018 08:25 #120945 by MaHo
hm2_5i25.0.7i76.0.0.enc0.count
also i checked enc1 but no.
18 Nov 2018 08:29 #120946 by PCW
I would verify that you have 5V swing on both A and B pins
and that the MPG common (ground) is connected to the Field I/O ground
Time to create page: 0.138 seconds
