Pendant sort of working...
30 Nov 2018 19:11 - 30 Nov 2018 20:34 #121665 by biqut2
Pendant sort of working... was created by biqut2
I changed from a wireless HB04 pendant to a proper 6 axis pendant on my machine today. Its setup and kind of working. I've verified all the proper signal are showing on hal meter. For some weird reason even though jog-incr-c changes to true when I select it on the pendant I can't get LinuxCNC to jog at that speed, only jog-incr-a and jog-incr-b work. Here is what I have in my hal file. Also, it may be a bit ambitious but this is a 4 axis machine and I'll like to map axes 5 and 6 to spindle and feed override if possible, just don't know how to do this.
# --- JOINT-SELECT-A ---
net joint-select-a     <=  hm2_5i25.0.7i77.0.0.input-16
# --- JOINT-SELECT-B ---
net joint-select-b     <=  hm2_5i25.0.7i77.0.0.input-17
# --- JOINT-SELECT-C ---
net joint-select-c     <=  hm2_5i25.0.7i77.0.0.input-18
# --- JOINT-SELECT-D ---
net joint-select-d     <=  hm2_5i25.0.7i77.0.0.input-19
# --- JOINT-SELECT-E ---
net joint-select-e     <=  hm2_5i25.0.7i77.0.0.input-20
# --- JOINT-SELECT-F ---
net joint-select-f     <=  hm2_5i25.0.7i77.0.0.input-21
# --- JOG-INCR-A ---
net jog-incr-a     <=  hm2_5i25.0.7i77.0.0.input-22
# --- JOG-INCR-B ---
net jog-incr-b     <=  hm2_5i25.0.7i77.0.0.input-23
# --- JOG-INCR-C ---
net jog-incr-c     <=  hm2_5i25.0.7i77.0.0.input-24
# ---jogwheel signals to mesa encoder - shared MPG---
net joint-selected-count     <=  hm2_5i25.0.encoder.03.count
#  ---mpg signals---
#       for axis x MPG
setp    axis.0.jog-vel-mode 1
net selected-jog-incr    =>  axis.0.jog-scale
net joint-select-a       =>  axis.0.jog-enable
net joint-selected-count =>  axis.0.jog-counts
#       for axis y MPG
setp    axis.1.jog-vel-mode 1
net selected-jog-incr    =>  axis.1.jog-scale
net joint-select-b       =>  axis.1.jog-enable
net joint-selected-count =>  axis.1.jog-counts
#       for axis z MPG
setp    axis.2.jog-vel-mode 1
net selected-jog-incr    =>  axis.2.jog-scale
net joint-select-c       =>  axis.2.jog-enable
net joint-selected-count =>  axis.2.jog-counts
#       for axis a MPG
setp    axis.3.jog-vel-mode 1
net selected-jog-incr    =>  axis.3.jog-scale
net joint-select-d       =>  axis.3.jog-enable
net joint-selected-count =>  axis.3.jog-counts
# connect selectable mpg jog increments
net jog-incr-a           =>  jogincr.sel0
net jog-incr-b           =>  jogincr.sel1
net jog-incr-c           =>  jogincr.sel2
net selected-jog-incr    <=  jogincr.out-f
    setp jogincr.debounce-time      0.200000
    setp jogincr.use-graycode      False
    setp jogincr.suppress-no-input False
    setp jogincr.in00          0.0000025
    setp jogincr.in01          0.0000250
    setp jogincr.in02          0.0002500
Edit:
Changing
to
setp jogincr.in07          0.0002500
fixed the problem with the third setting on the jog speed. Stil very interested in mapping so-count and fo-count to the 5th and 6th axes. Any help would be greatly appreciated.
Last edit: 30 Nov 2018 20:34 by biqut2.
30 Nov 2018 21:58 #121669 by biqut2
Replied by biqut2 on topic Pendant sort of working...
Nevermind, I feel like an idiot. After taking a short break and then looking at it again all I needed was:
gmoccapy.feed-override.counts and count-enable
Time to create page: 0.134 seconds
