How to start multiple limit3 instances, syntax question
  • cogzoid
  • cogzoid's Avatar Topic Author
  • Visitor
  • Visitor
05 Jan 2019 11:21 #123560 by cogzoid
For my project I'm going to need multiple limit3 instances to add to the thread, and each limit3 will control a different axis.
Here's how I got one to work:
loadrt limit3
addf limit3.0 servo-thread
However, I'm not sure how to add limit3.1, limit3.2, etc. Using more "addf" commands didn't work.
linuxcnc.org/docs/2.7/html/man/man9/limit3.9.html doesn't explain this very well.
I'm sure this is a simple syntax fix, but I'm not sure where to look up the answer.
05 Jan 2019 12:52 #123563 by islander261
Use the count= or names= option on the loadrt line. I like the names options because it gives me a clue about the use of each instance.
loadrt limit3 count=3
or
loadrt limit3 names=limit3.xaxis,limit3.yaxis,limit3.zaxis
addf limit3.xaxis servo-thread
addf limit3.yaxis servo-thread
addf limit3.zaxis servo-thread
The following user(s) said Thank You: cogzoid
Time to create page: 0.212 seconds
