Encoder Pins linked to LCNC
- CORBETT
- Thank you received: 113
11 May 2019 12:04 #133458
by CORBETT
Replied by CORBETT on topic Encoder Pins linked to LCNC
Andy,
Thanks for pointing me down the correct path... You are correct, I did not have it in the motmod line. I reworked the code and for the first time had the table sitting solid, BUT that was only after I jogged both axis. I assume I am off a little on the settings as it will sit solid after jogging, but if you disable the machine and then re-enable, the table will start slowly drifting until you jog both axis, then it will sit solid again. I still have to tune the PID loop, but it is finally jogging in correct directions and not acting crazy like before.
Thanks,
Robert
Thanks,
Robert
- CORBETT
11 May 2019 15:10 #133477
by CORBETT
SUCCESS SUCCESS SUCCESS.... It's working. Still a little bit of tuning left to tweak, but super happy.
Thanks to:
Todd
Tommy
Pete
Andy
Thanks for all of your help to get me pointed in the right direction. I still have a few things to tweak, but almost ready to make some parts again. This has turned out to be a awesome day.
Thanks again,
Robert
Thanks to:
Todd
Tommy
Pete
Andy
Thanks again,
Robert
Time to create page: 0.195 seconds
