Config for plasma table just drives me crazy
- KRAD-AT
04 Feb 2019 15:10 #125688
by KRAD-AT
Config for plasma table just drives me crazy was created by KRAD-AT
Hello guys,
I'm Martin a 29 years old Mechanical Engineer from Austria.
In the last weeks I built my first CNC machine - a plasma table.
It runs steppers via a parrallel port breakout board.
I hope somebody can help me with my problem.
At the moment everything works with this config:
INI:
HAL:
But i found a nice project on the internet: Thallias LinuxCNC Plasma with THC and the Files on GitLab
This guy built a nice config for his plasma table with torch height control.
I tried to make it work with my machine but the y-axis is way slower than x and z which are running great.
I looked at all the files for hours now and i can't find anything wrong.
INI:
HAL
Maybe someone here who is more experienced than me can help me or give me a hint where to look for the problem.
I appreciate any help!
Thank you so much!
Cheers, Martin
INI:
Warning: Spoiler!
# Generated by stepconf 1.1 at Mon Feb 4 14:03:51 2019
# Änderungen an dieser Datei werden beim nächsten
# Aufruf von stepconf überschrieben.
[EMC]
MACHINE = Plasma_3
DEBUG = 0
[DISPLAY]
DISPLAY = axis
EDITOR = gedit
POSITION_OFFSET = RELATIVE
POSITION_FEEDBACK = ACTUAL
ARCDIVISION = 64
GRIDS = 10mm 20mm 50mm 100mm 1in 2in 5in 10in
MAX_FEED_OVERRIDE = 1.2
MIN_SPINDLE_OVERRIDE = 0.5
MAX_SPINDLE_OVERRIDE = 1.2
DEFAULT_LINEAR_VELOCITY = 15.00
MIN_LINEAR_VELOCITY = 0
MAX_LINEAR_VELOCITY = 150.00
INTRO_TIME = 5
PROGRAM_PREFIX = /home/linuxcnc/linuxcnc/nc_files
INCREMENTS = 5mm 1mm .5mm .1mm .05mm .01mm .005mm
PYVCP = custompanel.xml
[FILTER]
png = image-to-gcode
gif = image-to-gcode
jpg = image-to-gcode
py = python
[TASK]
TASK = milltask
CYCLE_TIME = 0.010
[RS274NGC]
PARAMETER_FILE = linuxcnc.var
[EMCMOT]
EMCMOT = motmod
COMM_TIMEOUT = 1.0
COMM_WAIT = 0.010
BASE_PERIOD = 100000
SERVO_PERIOD = 1000000
[HAL]
HALUI = halui
HALFILE = Plasma_3.hal
HALFILE = custom.hal
POSTGUI_HALFILE = custom_postgui.hal
[HALUI]
# HalUI-MDI-Befehle hier einfügen (max. 64)
[TRAJ]
AXES = 3
COORDINATES = X Y Z
LINEAR_UNITS = mm
ANGULAR_UNITS = degree
CYCLE_TIME = 0.010
DEFAULT_VELOCITY = 15.00
MAX_VELOCITY = 150.00
[EMCIO]
EMCIO = io
CYCLE_TIME = 0.100
TOOL_TABLE = tool.tbl
[AXIS_0]
TYPE = LINEAR
HOME = 0.0
MAX_ACCELERATION = 750.0
STEPGEN_MAXACCEL = 937.5
SCALE = 20.0
FERROR = 1
MIN_FERROR = .25
MIN_LIMIT = -0.001
MAX_LIMIT = 1330.0
HOME_OFFSET = 0.0
[AXIS_1]
TYPE = LINEAR
HOME = 0.0
SCALE = 20.0
FERROR = 1
MIN_FERROR = .25
MIN_LIMIT = -0.001
MAX_LIMIT = 1100.0
HOME_OFFSET = 0.0
[AXIS_2]
TYPE = LINEAR
HOME = 0.0
MAX_VELOCITY = 95.0
SCALE = 100.0
FERROR = 1
MIN_FERROR = .25
MIN_LIMIT = 0.0
MAX_LIMIT = 50.0
HOME_OFFSET = 0.0
[EMC]
MACHINE = Plasma_3
DEBUG = 0
[DISPLAY]
DISPLAY = axis
EDITOR = gedit
ARCDIVISION = 64
INTRO_TIME = 5
[FILTER]
py = python
[TASK]
TASK = milltask
CYCLE_TIME = 0.010
[RS274NGC]
[EMCMOT]
EMCMOT = motmod
COMM_TIMEOUT = 1.0
COMM_WAIT = 0.010
[HAL]
HALUI = halui
[HALUI]
[TRAJ]
AXES = 3
COORDINATES = X Y Z
LINEAR_UNITS = mm
CYCLE_TIME = 0.010
[EMCIO]
EMCIO = io
CYCLE_TIME = 0.100
[AXIS_0]
TYPE = LINEAR
HOME = 0.0
SCALE = 20.0
FERROR = 1
MIN_FERROR = .25
MIN_LIMIT = -0.001
MAX_LIMIT = 1330.0
HOME_OFFSET = 0.0
[AXIS_1]
TYPE = LINEAR
HOME = 0.0
SCALE = 20.0
FERROR = 1
MIN_FERROR = .25
MIN_LIMIT = -0.001
MAX_LIMIT = 1100.0
HOME_OFFSET = 0.0
[AXIS_2]
TYPE = LINEAR
HOME = 0.0
MAX_VELOCITY = 95.0
SCALE = 100.0
FERROR = 1
MIN_FERROR = .25
MIN_LIMIT = 0.0
MAX_LIMIT = 50.0
HOME_OFFSET = 0.0
HAL:
Warning: Spoiler!
loadrt trivkins
loadrt [EMCMOT]EMCMOT base_period_nsec=[EMCMOT]BASE_PERIOD servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[TRAJ]AXES
loadrt hal_parport cfg="0 out"
setp parport.0.reset-time 5000
loadrt stepgen step_type=0,0,0
addf stepgen.update-freq servo-thread
net spindle-cmd-rpm <= motion.spindle-speed-out
net spindle-cmd-rpm-abs <= motion.spindle-speed-out-abs
net spindle-cmd-rps <= motion.spindle-speed-out-rps
net spindle-cmd-rps-abs <= motion.spindle-speed-out-rps-abs
net spindle-at-speed => motion.spindle-at-speed
net spindle-cw <= motion.spindle-forward
setp parport.0.pin-02-out-invert 1
net xstep => parport.0.pin-02-out
setp parport.0.pin-02-out-reset 1
net xdir => parport.0.pin-03-out
setp parport.0.pin-04-out-invert 1
net ystep => parport.0.pin-04-out
setp parport.0.pin-04-out-reset 1
net ydir => parport.0.pin-05-out
setp parport.0.pin-06-out-invert 1
net ystep => parport.0.pin-06-out
setp parport.0.pin-06-out-reset 1
net ydir => parport.0.pin-07-out
setp parport.0.pin-08-out-invert 1
net zstep => parport.0.pin-08-out
setp parport.0.pin-08-out-reset 1
setp parport.0.pin-09-out-invert 1
net zdir => parport.0.pin-09-out
setp parport.0.pin-14-out-invert 1
net spindle-cw => parport.0.pin-14-out
setp stepgen.0.position-scale [AXIS_0]SCALE
setp stepgen.0.steplen 1
setp stepgen.0.stepspace 0
setp stepgen.0.dirhold 30000
setp stepgen.0.dirsetup 30000
setp stepgen.0.maxaccel [AXIS_0]STEPGEN_MAXACCEL
net xpos-cmd axis.0.motor-pos-cmd => stepgen.0.position-cmd
net xpos-fb stepgen.0.position-fb => axis.0.motor-pos-fb
net xstep <= stepgen.0.step
net xdir <= stepgen.0.dir
net xenable axis.0.amp-enable-out => stepgen.0.enable
setp stepgen.1.position-scale [AXIS_1]SCALE
setp stepgen.1.steplen 1
setp stepgen.1.stepspace 0
setp stepgen.1.dirhold 30000
setp stepgen.1.dirsetup 30000
setp stepgen.1.maxaccel [AXIS_1]STEPGEN_MAXACCEL
net ypos-cmd axis.1.motor-pos-cmd => stepgen.1.position-cmd
net ypos-fb stepgen.1.position-fb => axis.1.motor-pos-fb
net ystep <= stepgen.1.step
net ydir <= stepgen.1.dir
net yenable axis.1.amp-enable-out => stepgen.1.enable
setp stepgen.2.position-scale [AXIS_2]SCALE
setp stepgen.2.steplen 1
setp stepgen.2.stepspace 0
setp stepgen.2.dirhold 30000
setp stepgen.2.dirsetup 30000
setp stepgen.2.maxaccel [AXIS_2]STEPGEN_MAXACCEL
net zpos-cmd axis.2.motor-pos-cmd => stepgen.2.position-cmd
net zpos-fb stepgen.2.position-fb => axis.2.motor-pos-fb
net zstep <= stepgen.2.step
net zdir <= stepgen.2.dir
net zenable axis.2.amp-enable-out => stepgen.2.enable
net estop-out => iocontrol.0.emc-enable-in
net tool-change iocontrol.0.tool-change => hal_manualtoolchange.change
net tool-changed iocontrol.0.tool-changed <= hal_manualtoolchange.changed
loadrt trivkins
INI:
Warning: Spoiler!
# Generated by stepconf 1.1 at Wed Dec 31 21:44:35 2003
# overwritten when you run stepconf again
[EMC]
MACHINE = plasma
DEBUG = 0
[DISPLAY]
DISPLAY = axis
PYVCP = widget.xml
EDITOR = gedit
ARCDIVISION = 64
DEFAULT_LINEAR_VELOCITY = 100.00
MAX_LINEAR_VELOCITY = 300.00
INTRO_TIME = 5
PROGRAM_PREFIX = /home/cw/desktop
[FILTER]
py = python
[TASK]
TASK = milltask
CYCLE_TIME = 0.010
[RS274NGC]
[EMCMOT]
EMCMOT = motmod
COMM_TIMEOUT = 1.0
COMM_WAIT = 0.010
[HAL]
HALFILE = plasma.hal
POSTGUI_HALFILE = widget.hal
[TRAJ]
AXES = 3
COORDINATES = X Y Z
LINEAR_UNITS = mm
CYCLE_TIME = 0.010
MAX_VELOCITY = 200.00
[EMCIO]
EMCIO = io
CYCLE_TIME = 0.100
[AXIS_0]
TYPE = LINEAR
HOME = 0.0
MAX_VELOCITY = 300.0
SCALE = 20.0
FERROR = 1
MIN_FERROR = .25
MIN_LIMIT = -0.001
MAX_LIMIT = 1330.0
HOME_OFFSET = 0.0
[AXIS_1]
TYPE = LINEAR
HOME = 0.0
AX_VELOCITY = 150.0
STEPGEN_MAXACCEL = 500.0
SCALE = 20.0
FERROR = 1
MIN_FERROR = .25
MIN_LIMIT = -0.001
MAX_LIMIT = 1100.0
HOME_OFFSET = 0.0
[AXIS_2]
TYPE = LINEAR
HOME = 0.0
MAX_VELOCITY = 95.0
SCALE = 100.0
FERROR = 1
MIN_FERROR = .25
MIN_LIMIT = -55.0
MAX_LIMIT = 0.001
HOME_OFFSET = 0.0
[EMC]
MACHINE = plasma
DEBUG = 0
[DISPLAY]
DISPLAY = axis
PYVCP = widget.xml
EDITOR = gedit
ARCDIVISION = 64
INTRO_TIME = 5
[FILTER]
py = python
[TASK]
TASK = milltask
CYCLE_TIME = 0.010
[RS274NGC]
[EMCMOT]
EMCMOT = motmod
COMM_TIMEOUT = 1.0
COMM_WAIT = 0.010
[HAL]
[TRAJ]
AXES = 3
COORDINATES = X Y Z
LINEAR_UNITS = mm
CYCLE_TIME = 0.010
[EMCIO]
EMCIO = io
CYCLE_TIME = 0.100
[AXIS_0]
TYPE = LINEAR
HOME = 0.0
SCALE = 20.0
FERROR = 1
MIN_FERROR = .25
MIN_LIMIT = -0.001
MAX_LIMIT = 1330.0
HOME_OFFSET = 0.0
[AXIS_1]
TYPE = LINEAR
HOME = 0.0
AX_VELOCITY = 150.0
SCALE = 20.0
FERROR = 1
MIN_FERROR = .25
MIN_LIMIT = -0.001
MAX_LIMIT = 1100.0
HOME_OFFSET = 0.0
[AXIS_2]
TYPE = LINEAR
HOME = 0.0
MAX_VELOCITY = 95.0
SCALE = 100.0
FERROR = 1
MIN_FERROR = .25
MIN_LIMIT = -55.0
MAX_LIMIT = 0.001
HOME_OFFSET = 0.0
HAL
Warning: Spoiler!
loadrt trivkins
loadrt pwmgen output_type=1
loadrt thcud
addf thcud servo-thread
addf pwmgen.make-pulses base-thread
net spindle-cmd-rpm => pwmgen.0.value
net spindle-on <= motion.spindle-on => pwmgen.0.enable
net spindle-pwm <= pwmgen.0.pwm
setp pwmgen.0.pwm-freq 100.0
setp pwmgen.0.scale 1166.66666667
setp pwmgen.0.offset 0.114285714286
setp pwmgen.0.dither-pwm true
#net estop-out => parport.0.pin-01-out
net spindle-cw => parport.0.pin-17-out
net spindle-pwm => parport.0.pin-16-out
net spindle-on => parport.0.pin-14-out
### THC STUFF ####
#net torch-on motion.spindle-on => thcud.torch-on => parport.0.pin-17-out
net arc_ok thcud.arc-ok <= parport.0.pin-12-in-not => motion.digital-in-00
net torch-up thcud.torch-up <= parport.0.pin-13-in-not
net torch-down thcud.torch-down <= parport.0.pin-11-in-not
net probe-switch motion.probe-input <= parport.0.pin-10-in-not
net torch-curr-vel thcud.current-vel <= motion.current-vel
net torch-req-vel thcud.requested-vel <= motion.requested-vel
# Change these.
#net correct-vel thcud.correction-vel
setp thcud.correction-vel 0.00001
setp thcud.velocity-tol 1
#setp thcud.vel-status true
#setp thcud.enable true
#setp thcud.arc-ok true
setp thcud.torch-on true
#net zpos-cmd axis.2.motor-pos-cmd => stepgen.2.position-cmd
#net zpos-fb stepgen.2.position-fb => axis.2.motor-pos-fb
# THC stuff (z)
net zpos-cmd thcud.z-pos-in <= axis.2.motor-pos-cmd
net thc-pos-cmd thcud.z-pos-out => stepgen.2.position-cmd
net zpos-fb axis.2.motor-pos-fb <= thcud.z-fb-out
loadrt trivkins
loadrt thcud
### THC STUFF ####
# Change these.
# THC stuff (z)
Thank you so much!
Cheers, Martin
- Thank you received: 7504
04 Feb 2019 15:31 #125689
Replied by tommylight on topic Config for plasma table just drives me crazy
Hallo Martin,
we would need a lot more info about the hardware you are using, especially the THC if using one.
MFG,
Tom
MFG,
Tom
- KRAD-AT
04 Feb 2019 15:53 #125692
by KRAD-AT
Replied by KRAD-AT on topic Config for plasma table just drives me crazy
Hello Tommy!
I just ordered an unit from poscope LINK
I hope it will arrive within this week.
But at the moment my biggest problem is the movement of the Y-Axis.
X and Z move great but the Y-Axis is extremely slow. It hardly moves.
Thank you for your fast reply!
04 Feb 2019 17:09 #125702
What drives and motors ?
Do drives have microstepping? How is it set up?
Could it be that you have different settings for X and Z to that of Y ?
- phillc54
- Thank you received: 2100
04 Feb 2019 21:32 #125715
by phillc54
Replied by phillc54 on topic Config for plasma table just drives me crazy
In the second ini file you have:instead of
Cheers, Phill.
AX_VELOCITY = 150.0MAX_VELOCITY = 150.0Cheers, Phill.
- KRAD-AT
05 Feb 2019 00:05 #125720
by KRAD-AT
OMG how could I not see this!?
Thank you!
I will test it later today.
Martin
Thank you!
Martin
Time to create page: 0.271 seconds
