Debian stretch 64Bit b&r Acopos VFD trouble
- BigDo
- Thank you received: 8
09 May 2019 10:00 - 09 May 2019 10:09 #133245
by BigDo
Debian stretch 64Bit b&r Acopos VFD trouble was created by BigDo
hi all,
i had linuxcnc installed on a ubuntu Precise 32Bit system and compiled the VFD Modbus HAL component for my B&R AcoposInverter S44 derived from git.mah.priv.at/gitweb/emc2-dev.git/shor...ads/altivar-vfd-comp (btw this link is dead) from wiki.linuxcnc.org/cgi-bin/wiki.pl?VFD_Modbus under 32 bit has also worked well. Now I have the new stretch 64 bit installed and get an error message:
I think I have to recompile the component for the 64 bit system but I do not know what I have to change.
Can anyone help me with that?
I tried to compile it but:
Niko
PS: By the way, the manufacturer of VFD of Bernecker + Rainer (B&R automation) probably Schneider Electric. Altivar VFD and AcoposInverter have the same menu structure
Found file (REL): ./custom.hal
Shutting down and cleaning up LinuxCNC ...
Killing task linuxcncsvr, PID = 6123
Debug file information:
Note: Using POSIX realtime
./custom.hal:7: execv (BRacopos_vfd): Permission denied
./custom.hal:7: waitpid failed BRacopos_vfd spindle-vfd
./custom.hal:7: BRacopos_vfd exited without becoming ready
6123
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
Note: Using POSIX realtimeI think I have to recompile the component for the 64 bit system but I do not know what I have to change.
cnc@cnc:~/BRacopos_vfd$ make BRacopos_vfd
Makefile:43: Warnung: Die Befehle fur das Ziel „install“ werden uberschrieben
/usr/share/linuxcnc/Makefile.modinc:104: Warnung: Alte Befehle fur das Ziel „install“ werden ignoriert
gcc -o BRacopos_vfd .o/BRacopos_vfd.o .o/modbus.o -Wl,-rpath,/usr/lib -L/usr/lib -llinuxcnchal -lglib-2.0
/usr/bin/ld: i386 architecture of input file `.o/BRacopos_vfd.o' is incompatible with i386:x86-64 output
/usr/bin/ld: i386 architecture of input file `.o/modbus.o' is incompatible with i386:x86-64 output
collect2: error: ld returned 1 exit status
Makefile:47: die Regel fur Ziel „BRacopos_vfd“ scheiterte
make: *** [BRacopos_vfd] Fehler 1Niko
Last edit: 09 May 2019 10:09 by BigDo.
09 May 2019 13:06 #133263
Replied by andypugh on topic Debian stretch 64Bit b&r Acopos VFD trouble
I haven't looked in any detail at your files (or, in fact, at all)
But have you tried compiling and installing the .c file with halcompile?
- BigDo
11 May 2019 06:20 - 13 May 2019 04:54 #133443
by BigDo
Replied by BigDo on topic Debian stretch 64Bit b&r Acopos VFD trouble
thx for answer andy.
I have precompiled 32Bit BRacopos_vfd component in /usr/bin but if I start linuxcnc i get an error message:
can i in general use 32Bit scripts under linux 64Bit?
after some changes i tried
halcompile --compile --userspace BRacoposS44.c
PS: after sudo apt-get install libmodbus-dev
the modbus header files were not in /usr/include where halcompile search for them but in /usr/include/modbus
./custom.hal:7: execv(BRacopos_vfd): No such file or directory
./custom.hal:7: BRacopos_vfd exited without becoming readycan i in general use 32Bit scripts under linux 64Bit?
gcc -Os -g -I. -I/build/linuxcnc-2.7.14/src/include -DUSPACE -fno-fast-math -mieee-fp -fno-unsafe-math-optimizations -DRTAPI -D_GNU_SOURCE -Drealtime -D__MODULE__ -I/usr/include/linuxcnc -Wframe-larger-than=2560 -DSIM -fPIC -URTAPI -U__MODULE__ -DULAPI -Os -o BRacoposS44 /tmp/tmpF0k_sg/BRacoposS44.c -Wl,-rpath,/lib -L/lib -llinuxcnchal
/tmp/ccCQE6MZ.o: In function `windup':
/tmp/tmpF0k_sg/BRacoposS44.c:222: undefined reference to `modbus_strerror'
/tmp/ccCQE6MZ.o: In function `findkwd':
/tmp/tmpF0k_sg/BRacoposS44.c:271: undefined reference to `iniFind'
/tmp/ccCQE6MZ.o: In function `read_ini':
/tmp/tmpF0k_sg/BRacoposS44.c:304: undefined reference to `iniFindInt'
/tmp/tmpF0k_sg/BRacoposS44.c:306: undefined reference to `iniFindInt'
/tmp/tmpF0k_sg/BRacoposS44.c:307: undefined reference to `iniFindInt'
/tmp/tmpF0k_sg/BRacoposS44.c:308: undefined reference to `iniFindInt'
/tmp/tmpF0k_sg/BRacoposS44.c:309: undefined reference to `iniFindInt'
/tmp/ccCQE6MZ.o:/tmp/tmpF0k_sg/BRacoposS44.c:310: more undefined references to `iniFindInt' follow
/tmp/tmpF0k_sg/BRacoposS44.c:317: undefined reference to `iniFind'
/tmp/ccCQE6MZ.o: In function `write_data':
/tmp/tmpF0k_sg/BRacoposS44.c:362: undefined reference to `modbus_write_register'
/tmp/tmpF0k_sg/BRacoposS44.c:374: undefined reference to `round'
/tmp/tmpF0k_sg/BRacoposS44.c:375: undefined reference to `round'
/tmp/tmpF0k_sg/BRacoposS44.c:409: undefined reference to `modbus_write_register'
/tmp/tmpF0k_sg/BRacoposS44.c:430: undefined reference to `modbus_write_register'
/tmp/ccCQE6MZ.o: In function `read_initial':
/tmp/tmpF0k_sg/BRacoposS44.c:453: undefined reference to `modbus_read_registers'
/tmp/tmpF0k_sg/BRacoposS44.c:459: undefined reference to `modbus_read_registers'
/tmp/tmpF0k_sg/BRacoposS44.c:460: undefined reference to `modbus_read_registers'
/tmp/tmpF0k_sg/BRacoposS44.c:461: undefined reference to `modbus_read_registers'
/tmp/tmpF0k_sg/BRacoposS44.c:462: undefined reference to `modbus_read_registers'
/tmp/tmpF0k_sg/BRacoposS44.c:478: undefined reference to `modbus_strerror'
/tmp/ccCQE6MZ.o: In function `read_data':
/tmp/tmpF0k_sg/BRacoposS44.c:496: undefined reference to `modbus_read_registers'
/tmp/tmpF0k_sg/BRacoposS44.c:501: undefined reference to `modbus_read_registers'
/tmp/tmpF0k_sg/BRacoposS44.c:504: undefined reference to `modbus_read_registers'
/tmp/tmpF0k_sg/BRacoposS44.c:520: undefined reference to `modbus_read_registers'
/tmp/tmpF0k_sg/BRacoposS44.c:524: undefined reference to `modbus_read_registers'
/tmp/ccCQE6MZ.o:/tmp/tmpF0k_sg/BRacoposS44.c:527: more undefined references to `modbus_read_registers' follow
/tmp/tmpF0k_sg/BRacoposS44.c:557: undefined reference to `modbus_strerror'
/tmp/ccCQE6MZ.o: In function `toggle_modbus_debug':
/tmp/tmpF0k_sg/BRacoposS44.c:233: undefined reference to `modbus_set_debug'
/tmp/tmpF0k_sg/BRacoposS44.c:227: undefined reference to `modbus_close'
/tmp/ccCQE6MZ.o: In function `main':
/tmp/tmpF0k_sg/BRacoposS44.c:720: undefined reference to `modbus_new_rtu'
/tmp/tmpF0k_sg/BRacoposS44.c:721: undefined reference to `modbus_strerror'
/tmp/tmpF0k_sg/BRacoposS44.c:726: undefined reference to `modbus_set_slave'
/tmp/tmpF0k_sg/BRacoposS44.c:730: undefined reference to `modbus_connect'
/tmp/tmpF0k_sg/BRacoposS44.c:731: undefined reference to `modbus_strerror'
/tmp/tmpF0k_sg/BRacoposS44.c:736: undefined reference to `modbus_set_debug'
/tmp/tmpF0k_sg/BRacoposS44.c:737: undefined reference to `modbus_set_slave'
/tmp/tmpF0k_sg/BRacoposS44.c:781: undefined reference to `modbus_flush'
/tmp/tmpF0k_sg/BRacoposS44.c:783: undefined reference to `modbus_write_register'
/tmp/tmpF0k_sg/BRacoposS44.c:785: undefined reference to `modbus_strerror'
/tmp/tmpF0k_sg/BRacoposS44.c:798: undefined reference to `modbus_flush'
/tmp/tmpF0k_sg/BRacoposS44.c:799: undefined reference to `modbus_close'
/tmp/tmpF0k_sg/BRacoposS44.c:803: undefined reference to `modbus_connect'
/tmp/tmpF0k_sg/BRacoposS44.c:807: undefined reference to `modbus_strerror'
Makefile:2: die Regel für Ziel „BRacoposS44“ scheiterte
make: *** [BRacoposS44] Fehler 1PS: after sudo apt-get install libmodbus-dev
Last edit: 13 May 2019 04:54 by BigDo.
15 May 2019 07:02 #133832
Yes, halcompile struggles a bit with C (or .comp) files with #INCLUDEs.
That same gcc command line with a -I... to the place where the modbus code can be found might be worth a try.
- BigDo
16 May 2019 11:59 - 17 May 2019 08:16 #133986
by BigDo
and finaly it works.
tested with b&r Acoposinverter S44 also should work with some Telemecanique/Schneider electric Altivar-vfd
i have installed
linuxcnc-stretch-uspace-amd64.iso
btw: nice latency on Asus P5E3 Pro 8GB RAM Intenso SSD 120GB and Nvidia GTX 460 (with "isolcpus=2,3")
Servo thread(1ms): 2602
Base thread(25us); 14131
i have installed
Last edit: 17 May 2019 08:16 by BigDo.
Time to create page: 0.279 seconds
