stepgen for dummies
  • felixcnc
  • felixcnc's Avatar Topic Author
  • Junior Member
  • Junior Member
23 Jun 2019 09:57 #137655 by felixcnc
stepgen for dummies was created by felixcnc
Hello,
As usual I am asking the very basic questions (sorry about this), but LinuxCNC is so vast that sometimes I feel overwhelmed about the amount of information I found but my lack of knowledge makes difficult to get to the right answer.
I've been reading : linuxcnc.org/docs/html/hal/rtcomps.html#...tcomps.html#_stepgen and even though it's very clear it does not fit exactly what I need to do.
Basically what I want to do is to create ONE very simple stepgen that takes a float and encodes that into two pins, I have created this very simple HAL code:
loadrt threads name1=probando period1=1000000
loadrt stepgen step_type=0
net direccion stepgen.0.dir
net paso stepgen.0.step
setp stepgen.0.position-scale 10000
setp stepgen.0.enable 1
addf stepgen.update-freq probando
addf stepgen.make-pulses probando
start
I was able to start halscope and retrieve information from stepgen.0.dir and stepgen.0.step however I am not 100% if I am things right.
For example if I write:
setp stepgen.0.position-cmd 1
I see the stepgen.0.dir and stepgen.0.step to change its value (if I set the value to other values sometimes it changes the values sometimes it doesnt).
So my question is.... if I use net to wire the setp stepgen.0.position-cmd 1 with a Joint position output from any of the kinematic examples , is that the right way to OUTPUT the movement through the step generator?
p.s. I hope I was clear, otherwise, please ask me and I'll be happy to clarify myself. And again, please forgive if I ask the obvious things, but I'm still ramping up on this.
Thank you very much
Kind regards
23 Jun 2019 10:56 #137658 by PCW
Replied by PCW on topic stepgen for dummies
Yes, something like
net some_appropriate_signal_name joint.0.motor-pos-cmd stepgen.0.position-cmd
Note
1. signal names are arbitrary (but chosen for readability)
2. you can use stepconf created hal files as examples
  • felixcnc
  • Junior Member
  • Junior Member
23 Jun 2019 14:59 #137664 by felixcnc
Replied by felixcnc on topic stepgen for dummies
Ahhh, yes, I saw that "net" is not only to wire things , but also since it creates a virtual pin when you use it, it is used to "alias" other pins as well.
Thanks for the advise.
23 Jun 2019 15:08 - 23 Jun 2019 15:18 #137665 by PCW
Right though strictly, its not really a pin but rather a signal
I think of signals as "wires"
so
net blue_wire out_pin_a
net blue_wire in_pin_b
connects the pins out_a and in_b with the wire blue_wire
or the equivalent
net blue_wire out_pin_a in_pin_b
or
net blue_wire out_pin_a => in_pin_b
The => is just for looks to give the person reading the hal file a hint about the direction of data flow.
in fact its really just a special inline comment.
Last edit: 23 Jun 2019 15:18 by PCW. Reason: clarify more
The following user(s) said Thank You: HueyHQ
Time to create page: 0.228 seconds
