More control over waiting for the spindle to come up to speed?
- JetForMe
- Thank you received: 27
26 Jun 2019 17:26 #137936
by JetForMe
More control over waiting for the spindle to come up to speed? was created by JetForMe
I was able to get linuxcnc to wait for the spindle to come up to speed using spindle.0.at-speed, but this only causes it to wait before doing a feed move. Moreover, since my at-speed input is based on the VFD's output frequency and not the actual spindle speed, I'd like to introduce a delay of a second or two after the input asserts to ensure the spindle is all the way up to speed.
Also, is there any way to delay rapids, as well, until the spindle is up to speed?
Since I probably want to ensure the spindle-stopped input also gives the spindle time to come to a complete stop, maybe the best way to handle this is to add some kind of delay to the two inputs. Perhaps timedelay is the way to do this?
- Thank you received: 4154
26 Jun 2019 19:42 - 26 Jun 2019 19:43 #137944
Replied by rodw on topic More control over waiting for the spindle to come up to speed?
Yes. Try
Timedelay
Last edit: 26 Jun 2019 19:43 by rodw.
- Thank you received: 2181
26 Jun 2019 21:09 #137949
Replied by cmorley on topic More control over waiting for the spindle to come up to speed?
it is unusual to wait for a spindle to come up to speed before a rapid move - why do you wish this? You could surely do this with HAL plumbing using feed-inhibit while rapiding.
Chris M
Chris M
- JetForMe
26 Jun 2019 21:47 #137952
by JetForMe
Replied by JetForMe on topic More control over waiting for the spindle to come up to speed?
I'm just really nervous about this machine doing the right thing until I get everything perfected.
- phillc54
- Thank you received: 2100
26 Jun 2019 23:12 #137953
by phillc54
Cheers, Phill.
Replied by phillc54 on topic More control over waiting for the spindle to come up to speed?
You could use a very small relative move to cause it to waitAlso, is there any way to delay rapids, as well, until the spindle is up to speed?
G91
G1 Z0.0001
G90Cheers, Phill.
27 Jun 2019 00:30 #137959
That's what rapid, feed and spindle override is for.
Chris M
Chris M
- pl7i92
- Thank you received: 359
27 Jun 2019 01:30 #137964
by pl7i92
Replied by pl7i92 on topic More control over waiting for the spindle to come up to speed?
why dont you ramp up the spindle
SOFT START
then you can be shure it is almost at the speed
as spindle at speed will acoor later and the vfd will get up slow
SOFT START
# load real time a limit2 and a near with names so it is easier to follow
loadrt limit2 names=spindle-ramp
loadrt near names=spindle-at-speed
# add the functions to a thread
addf spindle-ramp servo-thread
addf spindle-at-speed servo-thread
# set the parameter for max rate-of-change
# (max spindle accel/decel in units per second)
setp spindle-ramp.maxv 60
# hijack the spindle speed out and send it to spindle ramp in
net spindle-cmd <= motion.spindle-speed-out => spindle-ramp.in
# the output of spindle ramp is sent to the scale in
net spindle-ramped <= spindle-ramp.out => scale.0.in
# to know when to start the motion we send the near component
# (named spindle-at-speed) to the spindle commanded speed from
# the signal spindle-cmd and the actual spindle speed
# provided your spindle can accelerate at the maxv setting.
net spindle-cmd => spindle-at-speed.in1
net spindle-ramped => spindle-at-speed.in2
# the output from spindle-at-speed is sent to motion.spindle-at-speed
# and when this is true motion will start
net spindle-ready <= spindle-at-speed.out => motion.spindle-at-speed
The following user(s) said Thank You: JetForMe
27 Jun 2019 17:57 #138042
Do you have a spindle encoder? Even a single ppr encoder could be used to bypass this. (and it would catch more problems, too, like when I left my gearbox in neutral last weekend before starting the cycle.)
Replied by andypugh on topic More control over waiting for the spindle to come up to speed?
- JetForMe
27 Jun 2019 20:18 #138073
by JetForMe
Alas, if I did, this would be easier.
Time to create page: 0.204 seconds
