Lathe Collet User Mcode
  • Erikcnc
  • Erikcnc's Avatar Topic Author
  • Premium Member
  • Premium Member
19 Jul 2019 11:12 - 19 Jul 2019 11:13 #139898 by Erikcnc
Lathe Collet User Mcode was created by Erikcnc
Hi all,
After successfully add rpm displaying in Gmoccapy, i am continuing the build of my Emco Lathe machine.
I was away from honeymoon and now i got some time again to work on the lathe.
At the moment i am struggling to get it to work.
In the INI file i got
USER_M_PATH = (*specific map where my M-codes scripts are)
The executable files
--M101--
#!/bin/bash
# opens the collet closer
halcmd setp or2.1.in1 false
sleep 0.5
exit 0
--M102--
#!/bin/bash
# close the collet closer
halcmd setp or2.1.in1 true
sleep 0.5
exit 0
I even tried a m-code scripts like this for both
#!/bin/bash
halcmd sets user_m101m102code 0
sleep 0.5
exit 0
In my Hal File
# --- M101 and M102 signal ---
loadrt or2 count=2
addf or2.1 servo-thread
net collet-closer-pedal hm2_7i76e.0.7i76.0.0.input-16 => or2.1.in0
net user_m101m102code => or2.1.in1
net collet-open-close or2.1.out => hm2_7i76e.0.7i76.0.0.output-15
What am i doing wrong here?
Last edit: 19 Jul 2019 11:13 by Erikcnc.
19 Jul 2019 13:14 #139904 by BigJohnT
Replied by BigJohnT on topic Lathe Collet User Mcode
We need to know what you expected, what you got and any exact error messages.
JT
The following user(s) said Thank You: Erikcnc
  • Erikcnc
  • Premium Member
  • Premium Member
19 Jul 2019 14:13 #139912 by Erikcnc
Replied by Erikcnc on topic Lathe Collet User Mcode
JT
I got no error message when executing the M-codes in MDI. While i am doing that, i watch output pin 15 in halshow.
So far, nothing is happening.
19 Jul 2019 15:02 - 19 Jul 2019 15:03 #139920 by BigJohnT
I just tested your M101 and M102 and they turn off and on or2.1.in1 and or2.1.out turns on and off as expected.
linuxcnc.org/docs/2.7/html/config/ini-co...ml#_rs274ngc_section
USER_M_PATH = myfuncs:/tmp/mcodes:experimentalmcodes - Specifies a list of colon (:) separated directories for user defined functions. Directories are specified relative to the current directory for the ini file or as absolute paths. The list must contain no intervening whitespace.
A search is made for each possible user defined function, typically (M100-M199). The search order is:
1. [DISPLAY]PROGRAM_PREFIX (if specified)
2. If [DISPLAY]PROGRAM_PREFIX is not specified, search the default location: nc_files
3. Then search each directory in the list [RS274NGC]USER_M_PATH
The first executable M1xx found in the search is used for each M1xx.
Do you have a M101 and M102 in the nc_files directory?
JT
Last edit: 19 Jul 2019 15:03 by BigJohnT.
  • Erikcnc
  • Premium Member
  • Premium Member
19 Jul 2019 15:58 #139924 by Erikcnc
In my ini file i got underneath [RS274NGC] the line USER_M_PATH with the direction to => /home/emco/linuxcnc/configs/EMCOTURN220/M-codes/
In the folder M-codes i got the two files that got the name M101 and M102.
Both are selected as executable file.
So why wouldn't hm2_7i76e.0.7i76.0.0.output-15 be triggerd? (in halshow it stays dark red)
19 Jul 2019 17:07 #139931 by BigJohnT
I have to guess that net user_m101m102code => or2.1.in1 is blocking the setp or2.1.in1.
If you run LinuxCNC from a terminal you will see this error
<commandline>:0: pin 'or2.1.in1' is connected to a signal
When in doubt run from a terminal so you can see all the errors.
JT
  • Erikcnc
  • Premium Member
  • Premium Member
21 Jul 2019 09:13 #140079 by Erikcnc
Thanks!!
i am not sure what really cause the problem, but it works perfectly now!
I made the m code scripts again, but changed the True and False to a 1 and 0.
I will share my files soon for those who would like to use it for something similar.
Time to create page: 0.160 seconds
