Feed override net to rapid override
27 Jul 2019 09:22 #140749 by JB-Motoring
Feed override net to rapid override was created by JB-Motoring
Hey guys,
I am looking for a nice solution of connecting the feed override with the rapid.
I would like to control both Actions with one rotary switch.
Feed override is now working with a rotary, so i only need to link the commands in hal, but HOW? :-)
Thanks in advance,
Joel
27 Jul 2019 12:22 #140755 by pl7i92
Replied by pl7i92 on topic Feed override net to rapid override
feed override
halui.feed−override.count−enable bit in (default: TRUE)
When TRUE, modify feed override when counts changes.
halui.feed−override.counts s32 in
counts X scale = feed override percentage
halui.feed−override.decrease bit in
pin for decreasing the FO (−=scale)
halui.feed−override.direct−value bit in
pin to enable direct value feed override input
halui.feed−override.increase bit in
pin for increasing the FO (+=scale)
halui.feed−override.scale float in
pin for setting the scale on changing the FO
halui.feed−override.value float out
current Feed Override value
rapid override
halui.rapid−override.count−enable bit in (default: TRUE)
When TRUE, modify Rapid Override when counts changes.
halui.rapid−override.counts s32 in
counts X scale = Rapid Override percentage
halui.rapid−override.decrease bit in
pin for decreasing the Rapid Override (−=scale)
halui.rapid−override.direct−value bit in
pin to enable direct value Rapid Override input
halui.rapid−override.increase bit in
pin for increasing the Rapid Override (+=scale)
halui.rapid−override.scale float in
pin for setting the scale on changing the Rapid Override
halui.rapid−override.value float out
current Rapid Override value
28 Jul 2019 16:42 #140846 by andypugh
Replied by andypugh on topic Feed override net to rapid override
For every line in the HAL that says something like
net signal-name halui.feed-overide,xxxx
Edit to say
net signal-name halui.feed-overide,xxxx halui.rapid-override.xxxxx
The following user(s) said Thank You: Todd Zuercher, JB-Motoring
29 Jul 2019 11:32 #140893 by JB-Motoring
Replied by JB-Motoring on topic Feed override net to rapid override
I can't find any net'd feed-overrides in my hal.
The only feed-override commands are setp for the rotary switches inputs.
Thank you :-)
29 Jul 2019 13:36 #140909 by andypugh
If feed override is working then it must be netted. Maybe you are looking in the wrong HAL file?
29 Jul 2019 17:02 #140925 by JB-Motoring
Hey Andy,
I finally got it working, i didnt See the last part to be netted.
Thank you very much for all the help :-))
Is there also a possibility to adjust the delay of the rapid override?
It seems, that the feed override reacts a bit faster.
I couldn't find a setp Name for that.
Thank you guys! :-)
31 Jul 2019 13:03 #141021 by andypugh
I am not sure what you mean by "delay". There shouldn't really be any delay.
31 Jul 2019 15:17 #141035 by JB-Motoring
Hey Andy,
It seems, that the feed override is a maybe a few ms quicker than the rapid.
But I think that this shouldn't be a Problem at all. Maybe the sliders Update a bit different.
Thank you :-)
31 Jul 2019 17:13 #141056 by andypugh
I suspect that the actual override happens before the GUI updates.
01 Aug 2019 15:30 #141143 by JB-Motoring
That is my thought, too.
I will try it out in Action tomorrow :-)
Thank you
