Turning output on and off from HAL show?
- thefabricator03
- Visitor
21 Aug 2019 03:43 #142707
by thefabricator03
Turning output on and off from HAL show? was created by thefabricator03
Hi Guys,
I did try to search for this but couldnt find what I was after,
What is the command to turn a output on and off from the HAL show test command line? I know it will be something simple.
- Thank you received: 5336
21 Aug 2019 07:19 - 21 Aug 2019 07:22 #142715
Replied by PCW on topic Turning output on and off from HAL show?
You can enter single hal statements in the small text box at the bottom of the hal show
pane labeled "Test HAL Command":
say
setp hm2_7i96.0.ssr.00.out-01 true
However, I find it much easier to open a terminal window and type
halcmd setp hm2_7i96.0.ssr.00.out-01 true
The benefits of doing it from the terminal via halcmd are that
1. You have command history, so you can re-do different commands just using the up/down keys.
2. halcmd is "smart" and has command completion (via the tab key) so you can type partial pin names
for example and have halcmd fill in the blanks (a double tab prints all matches so far)
That is:
halcmd setp hm2_7i96.0.ssr[TAB TAB] prints all pins that start with hm2_7i96.0.ssr as a guide for you to complete the command
say
That is:
Last edit: 21 Aug 2019 07:22 by PCW.
The following user(s) said Thank You: Clive S, thefabricator03
- thefabricator03
- Visitor
21 Aug 2019 15:54 #142739
by thefabricator03
Replied by thefabricator03 on topic Turning output on and off from HAL show?
Thanks PCW,
I tried typing this: setp hm2_7i76e.0.7i76.0.0.output-05 true in the halshow window but get this error,
setting parameter 'hm2_7i76e.0.7i76.0.0.output-05' to 'true'
pin 'hm2_7i76e.0.7i76.0.0.output-05' is connected to a signal
while executing
"hal setp hm2_7i76e.0.7i76.0.0.output-05 true"
("eval" body line 1)
invoked from within
"eval hal $what"
(procedure "showEx" line 2)
invoked from within
"showEx $halcommand"
invoked from within
".main.note.fps.f2.b.execute invoke"
("uplevel" body line 1)
invoked from within
"uplevel #0
while executing
invoked from within
"eval hal $what"
invoked from within
invoked from within
invoked from within
"uplevel #0
(procedure "tk::ButtonUp" line 22)
invoked from within
"tk::ButtonUp .main.note.fps.f2.b.execute"
(command bound to event)
21 Aug 2019 16:07 - 21 Aug 2019 16:11 #142740
Yes, you cannot the change the state of a pin that's already connected
to a hal signal (what would this mean?)
But you can unlink the pin and then set it
halcmd unlinkp hm2_7i76e.0.7i76.0.0.output-05
halcmd setp hm2_7i76e.0.7i76.0.0.output-05 true
halcmd setp hm2_7i76e.0.7i76.0.0.output-05 false
( and remember that its no longer connected until you restart linuxCNC or issue a net command that reconnects it )
Last edit: 21 Aug 2019 16:11 by PCW. Reason: clarify
- thefabricator03
- Visitor
21 Aug 2019 16:17 - 21 Aug 2019 16:29 #142742
by thefabricator03
Thanks PCW,
I was under the impression that I would be able to toggle the output easily, I guess I was wrong, That is why I could not get it to work before I make this thread. And yes it is already connected in the HAL I just wanted to test turning my air scribe on and off without configuring buttons in AXIS.
Last edit: 21 Aug 2019 16:29 by thefabricator03.
- Thank you received: 1482
21 Aug 2019 22:48 #142765
Replied by Todd Zuercher on topic Turning output on and off from HAL show?
If you don't yet have the signal you have that pin connected to connected to anything else. You can change the state of the signal (and the pin) with a sets command.
21 Aug 2019 23:03 #142769
And there is one situation where you can change the signal even when driven:
if both connected pins are bi-directional (this is handy for checking index_enable)
Time to create page: 0.214 seconds
