7i73 Encoder input velocity
- roland
- Thank you received: 64
07 Sep 2019 01:32 #144456
by roland
7i73 Encoder input velocity was created by roland
how can i read the velocity signal from the encoder input of a 7i73?
On the 7i76 there is a corresponding hal pin. On the 7i73 there is unfortunately no hal pin.
Kind regards
Roland
Kind regards
Roland
- Thank you received: 4154
07 Sep 2019 02:40 - 07 Sep 2019 02:40 #144461
If you review the manual, the encoders are for MPG's so they don't have the full range of pins the 7i76 spindle encoder has. With MPG's you just work with counts. You probably need a 7i85 to add spindle encoders.
Replied by rodw on topic 7i73 Encoder input velocity
Kind regards
Roland
Last edit: 07 Sep 2019 02:40 by rodw.
- Thank you received: 5336
07 Sep 2019 13:38 #144490
Replied by PCW on topic 7i73 Encoder input velocity
Right, the 7I73 encoder inputs are just intended for MPG use so they do no velocity estimation (you can use D/DT of count for a crude velocity estimate)
- roland
08 Sep 2019 06:57 #144514
by roland
Replied by roland on topic 7i73 Encoder input velocity
I've tried this with ddt now.
From a count rate of 2000 Hz or higher this works quite well with ddt and a lowpass filter.
My count rate is 0 to 1000 Hz. There the velocity signal is not stable.
08 Sep 2019 07:13 #144517
Well the lower speed you go, the longer time constant you would need on your filter for a stable velocity, If this is for a MPG, a 50 ms or so time constant should be OK
Time to create page: 0.114 seconds
