dab77 wrote: (...)
In the meantime I also want to ask: instead of calling "os.system("command")", is there a way to directly change a Hal Parameter in python? I've looked in the code, but didn't find anything about that..
Well, there are few ways how to solve this, you can create HAL Python Userspace component which will create the HAL pins which you will be changing in your Python written program. And then you connect these pins inside the HAL layer to actual pins you need to change. That is described here: linuxcnc.org/docs/html/hal/halmodule.html .
cmorley wrote: You don't have to connect pins. There are some functions to do direct commands - depends on the version of linuxcnc.
in 2.7 fairly limited:
